Giriş
The Poptone Chronograph LDF-51 is a fun, light-colored watch launched in 2011 by Casio primarily for the Asian market. It features a 22mm x 40mm face, electro-luminescence backlight and a water resistance of approximately 50 meters.
This guide will go over the basics of how to replace the battery of the watch as it is rated for a 3-year life.
Neye ihtiyacın var
First, we will want to make sure that you are working in a well-lit space and have an area to catch any of the screws that you will remove
Make sure to have a small Philips screwdriver like the J000 in the iFixit Pro Tech Toolkit
Lastly, you will need to make sure your have a pair of tweezers (recommended) or a thumbtack to remove the latch for the battery
Remove the back cover by unscrewing the four screws at the back using a J000 screwdriver
Take care not to strip the threads
Once all screws have been removed store them in a safe place
Carefully remove the back cover of the Poptone making sure not to flip the watch over
Carefully remove the sticker covering the back of the battery. We will be saving and re-applying it
To release the battery from the battery holder you will need to:
1. Place your tweezers in the latch and pull in the direction of the green arrow. If you do not have a pair a tweezer, use a tack and place the tack between the latch and battery space and pull out
2. Pull the latch all the way up to release the battery following the direction of the pink arrow
Be careful not to accidentally knock off one of the ground pins
Now we can remove the battery from the latch
The replacement battery type is a CR1216 3V with the OEM battery being a Sony
Follow these steps in reverse to reseat the battery and complete the replacement
To reassemble your device, please follow these instructions in reverse order.
