Ana içeriğe geç
Casio fx-9750GII Screen Replacement
Neye ihtiyacın var
  1. Casio fx-9750GII Screen Replacement, Screen: adım 1, 2 resimden 1. Casio fx-9750GII Screen Replacement, Screen: adım 1, 2 resimden 2.
    • Turn off the calculator and flip it over so the backside is facing up.
    • Slide the battery door off and remove all of the batteries.
  2. Casio fx-9750GII Screen Replacement: adım 2, 1 resimden 1.
    • Use a screwdriver to remove the screws from the back of the calculator.
  3. Casio fx-9750GII Screen Replacement: adım 3, 1 resimden 1.
    • Carefully remove the screw from the battery slot.
  4. Casio fx-9750GII Screen Replacement: adım 4, 2 resimden 1. Casio fx-9750GII Screen Replacement: adım 4, 2 resimden 2.
    • Remove the back case from the calculator.
    • Be careful of the spring that shows in the second picture. The spring is the convertor of the battery.
  5. Casio fx-9750GII Screen Replacement: adım 5, 2 resimden 1. Casio fx-9750GII Screen Replacement: adım 5, 2 resimden 2.
    • Remove the screws from the motherboard.
  6. Casio fx-9750GII Screen Replacement: adım 6, 2 resimden 1. Casio fx-9750GII Screen Replacement: adım 6, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Separate the screen cable from the motherboard using tweezers.
    • Remove the calculator screen.
    • Replace the screen.
  7. Casio fx-9750GII Screen Replacement: adım 7, 2 resimden 1. Casio fx-9750GII Screen Replacement: adım 7, 2 resimden 2.
    • Replace the board and back cover of the calculator, then install the batteries to test if the new screen works well.
Sonuç
YORK-CHEN-F21SEG[2]
145 İtibar
1 Kılavuz yazıldı
Ekip
2Kılavuz Yorumları
thanks for the short description and pics. my screen cable appears to be soldered directly. I would help if you said more than "separate the screen cable from the motherboard" Perhaps add another pic or two of just that description? Are you breaking the wires? are you soldering on the new replacement board? are you taking off just the screen from that main 'calculator' electronics board?
Happy Zahn - Yanıt
Where to get the new replacement screen?
Ahmed Farhat - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 34
Son 30 gün: 121
Her zaman: 4,042
