Ana içeriğe geç
Caterpillar B15 Rear Facing Camera Replacement
Neye ihtiyacın var
  1. Caterpillar B15 Rear Facing Camera Replacement, Caterpillar B15 Teardown: adım 1, 1 resimden 1.
    • Place the phone screen-side down and place thumb on the yellow and black switch. Slide the switch to the right to unlock the back covering for removal.
    FixBot'a Sor
    Yorum Ekle
  2. Caterpillar B15 Rear Facing Camera Replacement: adım 2, 2 resimden 1. Caterpillar B15 Rear Facing Camera Replacement: adım 2, 2 resimden 2.
    • Remove the back covering by gently lifting upwards from the bottom of the back covering. The back will snap off and the battery is exposed.
    FixBot'a Sor
    Yorum Ekle
  3. Caterpillar B15 Rear Facing Camera Replacement: adım 3, 2 resimden 1. Caterpillar B15 Rear Facing Camera Replacement: adım 3, 2 resimden 2.
    • Place index finger at the top edge of the battery and gently lift upwards. The battery will slide cleanly out of the phone.
    FixBot'a Sor
    Yorum Ekle
  4. Caterpillar B15 Rear Facing Camera Replacement: adım 4, 2 resimden 1. Caterpillar B15 Rear Facing Camera Replacement: adım 4, 2 resimden 2.
    • With the back cover removed, locate and remove the Phillips screw pictured top-center, and the two torx screws above and to either side of the Phillips screw. A T-5 bit is required for removal of the torx screws.
    • WARNING: Proceeding beyond this point will void the warranty for this device.
    FixBot'a Sor
    Yorum Ekle
  5. Caterpillar B15 Rear Facing Camera Replacement: adım 5, 1 resimden 1.
    • Next, remove the two torx (star-shaped) screws below the battery. These screws help to secure the outer shell of the phone around the motherboard. A T-5 bit is required for removal.
    FixBot'a Sor
    Yorum Ekle
  6. Caterpillar B15 Rear Facing Camera Replacement: adım 6, 1 resimden 1.
    • There are three remaining screws on each long side of the phone. A small hex bit is required for removal.
    FixBot'a Sor
    Yorum Ekle
  7. Caterpillar B15 Rear Facing Camera Replacement: adım 7, 1 resimden 1.
    • There is one more Phillips screw remaining. It is located beneath the headphone cover.
    FixBot'a Sor
    Yorum Ekle
  8. Caterpillar B15 Rear Facing Camera Replacement: adım 8, 1 resimden 1.
    • With all screws removed, the back and side pieces should come off the front of the phone, exposing the motherboard and various components as shown.
    FixBot'a Sor
    Yorum Ekle
  9. Caterpillar B15 Rear Facing Camera Replacement: adım 9, 1 resimden 1.
    • With all screws removed, move around the motherboard, carefully prying it from the remaining shell.
    FixBot'a Sor
    Yorum Ekle
  10. Caterpillar B15 Rear Facing Camera Replacement: adım 10, 1 resimden 1.
    • Finally, disconnect the chip seen in the upper right, and the board should pull away from the rest of the phone.
    FixBot'a Sor
    Yorum Ekle
  11. Caterpillar B15 Rear Facing Camera Replacement: adım 11, 1 resimden 1.
    • Congratulations. You have successfully disassembled the Caterpillar B15.
    FixBot'a Sor
    Yorum Ekle
  12. Caterpillar B15 Rear Facing Camera Replacement, Rear Facing Camera: adım 12, 2 resimden 1. Caterpillar B15 Rear Facing Camera Replacement, Rear Facing Camera: adım 12, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Locate the camera module (pictured). To access the component to be replaced, the protective metal casing must first be removed. There are small gaps at each corner in which tweezers will fit. Choose any two, and slide this piece off.
    FixBot'a Sor
    Yorum Ekle
  13. Caterpillar B15 Rear Facing Camera Replacement: adım 13, 1 resimden 1.
    • The module is also held in place by two small metal tabs to either side. To undo these, bend the bracket on both sides ever so slightly.
    FixBot'a Sor
    Yorum Ekle
  14. Caterpillar B15 Rear Facing Camera Replacement: adım 14, 1 resimden 1.
    • The camera module will now easily pull free.
    • When installing the new camera module, be sure to resecure the brackets on either side. A faint click should also be heard when pressing the new piece into its socket. These are the tabs hooking onto the brackets, and will signify it is in securely.
    FixBot'a Sor
    Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Geoffrey Mosdell
1.119 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 4-7, Brown Fall 2014 USF Tampa, Team 4-7, Brown Fall 2014 üyesi
USFT-BROWN-F14S4G7
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 8
Son 30 gün: 36
Her zaman: 2,751
