Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
Parçalar
Hiçbir parça belirtilmedi.
  1. Place the phone screen-side down and place thumb on the yellow and black switch. Slide the switch to the right to unlock the back covering for removal.
    • Place the phone screen-side down and place thumb on the yellow and black switch. Slide the switch to the right to unlock the back covering for removal.
  2. Remove the back covering by gently lifting upwards from the bottom of the back covering. The back will snap off and the battery is exposed. Remove the back covering by gently lifting upwards from the bottom of the back covering. The back will snap off and the battery is exposed.
    • Remove the back covering by gently lifting upwards from the bottom of the back covering. The back will snap off and the battery is exposed.
  3. Nintendo Switch Setleri
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. Place index finger at the top edge of the battery and gently lift upwards. The battery will slide cleanly out of the phone. The SIM card slot lies under the battery. Place index finger at the top edge of the battery and gently lift upwards. The battery will slide cleanly out of the phone. The SIM card slot lies under the battery.
    • Place index finger at the top edge of the battery and gently lift upwards. The battery will slide cleanly out of the phone. The SIM card slot lies under the battery.
  5. The old SIM card is removed and replaced with the new one. The phone can be reassembled by following these steps in reverse order.
    • The old SIM card is removed and replaced with the new one. The phone can be reassembled by following these steps in reverse order.
Sonuç
Geoffrey Mosdell
951 İtibar
5 adet Kılavuz yazıldı
Takım
USF Tampa, Team 4-7, Brown Fall 2014 USF Tampa, Team 4-7, Brown Fall 2014 üyesi
USFT-BROWN-F14S4G7
4 Üyeler
10 adet Kılavuz yazıldı
Bir Yorum
Mi celular dice SIM no detectada que puedo hacer
Jerson Vargas - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 16
Son 30 gün: 95
Her zaman: 11,271
