Ana içeriğe geç
Ceiling Fan Light Fixture Replacement
Neye ihtiyacın var
    1. Ceiling Fan Light  Fixture Replacement, Light Fixture: adım 1, 3 resimden 1. Ceiling Fan Light  Fixture Replacement, Light Fixture: adım 1, 3 resimden 2. Ceiling Fan Light  Fixture Replacement, Light Fixture: adım 1, 3 resimden 3.
      • Working with electrical wires could lead to electrocution.
      • Find your circuit breaker panel and turn off the breaker that corresponds to your ceiling lights.
      • Do this by pushing it to the right.
      • Also flip your light switch to off.
      FixBot'a Sor
      Yorum Ekle
    2. Ceiling Fan Light  Fixture Replacement: adım 2, 2 resimden 1. Ceiling Fan Light  Fixture Replacement: adım 2, 2 resimden 2.
      • Remove the two 1.4 mm Phillips head screws that hold the fixture to the fan itself.
      • Once loose, pull down to expose the two connecting wires.
      FixBot'a Sor
      Yorum Ekle
    3. Ceiling Fan Light  Fixture Replacement: adım 3, 3 resimden 1. Ceiling Fan Light  Fixture Replacement: adım 3, 3 resimden 2. Ceiling Fan Light  Fixture Replacement: adım 3, 3 resimden 3.
      • Disconnect these wires by twisting the caps in a counter-clockwise direction.
      • You only need to disconnect the wires coming from the lighting fixture.
      • Once both caps are removed, simply pull the wires apart to remove the fixture.
      FixBot'a Sor
      Yorum Ekle
    4. Ceiling Fan Light  Fixture Replacement: adım 4, 2 resimden 1. Ceiling Fan Light  Fixture Replacement: adım 4, 2 resimden 2.
      • Loosen the nut holding the ceiling fan piece to the lighting fixture.
      • This step may require a crescent wrench if finger force is not enough.
      FixBot'a Sor
      Yorum Ekle
    5. Ceiling Fan Light  Fixture Replacement: adım 5, 1 resimden 1.
      • Pull upwards to remove the fan piece that holds the light fixture.
      • Your model may require you to twist this piece in a counter-clockwise motion to remove.
      FixBot'a Sor
      Yorum Ekle
    6. Ceiling Fan Light  Fixture Replacement: adım 6, 1 resimden 1.
      • Switch out the old fixture with your new fixture by doing the last two steps in reverse order.
      FixBot'a Sor
      Yorum Ekle
    7. Ceiling Fan Light  Fixture Replacement: adım 7, 2 resimden 1. Ceiling Fan Light  Fixture Replacement: adım 7, 2 resimden 2.
      • To connect your new fixture, locate the black wire from your light and the colored wire from the fan.
      • Be sure to attached the colored wires to each other, and white wires to each other. (Positive-Positive, Negative-Negative)
      • Twist these together. Do the same with the two white wires.
      FixBot'a Sor
      Yorum Ekle
    8. Ceiling Fan Light  Fixture Replacement: adım 8, 2 resimden 1. Ceiling Fan Light  Fixture Replacement: adım 8, 2 resimden 2.
      • Your new light fixture should come with replacement caps. Twist these in a clockwise motion over your wire ends to ensure connection.
      • The old caps work just as well for this if you were not given new ones.
      FixBot'a Sor
      Yorum Ekle
    9. Ceiling Fan Light  Fixture Replacement: adım 9, 1 resimden 1.
      • Be sure to neatly tuck in all wires when re-attaching the fixture.
      • Failure to do this will result in not being able to correctly close the gap and put in the screws.
      FixBot'a Sor
      Yorum Ekle
    10. Ceiling Fan Light  Fixture Replacement: adım 10, 1 resimden 1.
      • Flip your breaker back on, turn on your light switch, and enjoy your new lights!
      FixBot'a Sor
      Yorum Ekle
Sonuç
12 farklı kişi bu kılavuzu tamamladı.
Garrett Janetzky
613 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 14-1, Green Fall 2015 Cal Poly, Team 14-1, Green Fall 2015 üyesi
CPSU-GREEN-F15S14G1
4 Üyeler
4 adet Kılavuz yazıldı
11Kılavuz Yorumları
Amazingly instructive, informative and concise. Brilliant.
Jeanie Bolin-Moore - Yanıt Paylaş
It's awesome
Nandish Reddy - Yanıt Paylaş
Just what I needed. Thanks.
bob.mohler - Yanıt Paylaş
Does it have remote control??
ceiling fan manufacturers in india
Abhijeet Khole - Yanıt Paylaş
Could someone provide the name of the light fixture used in the demonstration?
THOMAS DUFF - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 31
Son 30 gün: 140
Her zaman: 37,299
