Giriş
Replacing the display on this device is not very difficult. A couple sets of screws and wires are all that need removing, but don't rush or you might rip a cable.
  1. Lay the device on its back, and rotate so the base is facing away from you.
    • Lay the device on its back, and rotate so the base is facing away from you.
  2. Grip the frame with your fingers under the edge of the frame, and thumbs pushing down on the front of the device.
    • Grip the frame with your fingers under the edge of the frame, and thumbs pushing down on the front of the device.
    • Lift up the frame with your fingers and push down the rest of the device with your thumbs.
    • Remove the frame and matte from the device.
    • Remove the four 7mm Torx T6 screws.
    • Using the plastic opening tool or your fingers, lift up the frame from any edge.
    • Remove the frame from the device.
    • Unplug the cable connecting the display to the power supply using the flat end of the spudger to pry the connector away from the circuit board.
    • Alternate applying pressure to the left and right side of the connector to ensure that it does not break.
    • Lift up the display from the left edge and flip display over.
    • Do not lift the display too quickly, as the display is still connected to the main circuit board on the right.
    • Use the spudger to disconnect the ribbon cable from the display by the black pins away from the connector. There is a pin on either side of the connector.
    • Once both pins are released, the ribbon cable should slide easily out.
    • It may be easier if someone else holds the display so the cable does not get ripped out.
    • Remove the display assembly from the device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Casey Glasgow
510 İtibar
5 adet Kılavuz yazıldı
Takım
Cal Poly, Team 9-25, Maness Winter 2014 Cal Poly, Team 9-25, Maness Winter 2014 üyesi
CPSU-MANESS-W14S9G25
4 Üyeler
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 1
Her zaman: 90
