Ana içeriğe geç
Ceiva LF2003 Internal Plastic Screen Frame Replacement
Neye ihtiyacın var
  1. Ceiva LF2003 Internal Plastic Screen Frame Replacement, Exterior Frame and Matting: adım 1, 1 resimden 1.
    • Lay the device on its back, and rotate so the base is facing away from you.
  2. Ceiva LF2003 Internal Plastic Screen Frame Replacement: adım 2, 1 resimden 1.
    • Grip the frame with your fingers under the edge of the frame, and thumbs pushing down on the front of the device.
  3. Ceiva LF2003 Internal Plastic Screen Frame Replacement: adım 3, 1 resimden 1.
    • Lift up the frame with your fingers and push down the rest of the device with your thumbs.
  4. Ceiva LF2003 Internal Plastic Screen Frame Replacement: adım 4, 1 resimden 1.
    • Remove the frame and matte from the device.
  5. Ceiva LF2003 Internal Plastic Screen Frame Replacement, Internal Plastic Screen Frame: adım 5, 1 resimden 1.
    • Remove the four 7mm Torx T6 screws.
  6. Ceiva LF2003 Internal Plastic Screen Frame Replacement: adım 6, 2 resimden 1. Ceiva LF2003 Internal Plastic Screen Frame Replacement: adım 6, 2 resimden 2.
    • Using the plastic opening tool or your fingers, lift up the frame from any edge.
    • Remove the frame from the device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Casey Glasgow
510 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 9-25, Maness Winter 2014 Cal Poly, Team 9-25, Maness Winter 2014 üyesi
CPSU-MANESS-W14S9G25
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 86
