Ana içeriğe geç
Ceiva LF2003 Power Supply Board Replacement
Neye ihtiyacın var
  1. Ceiva LF2003 Power Supply Board Replacement, Exterior Frame and Matting: adım 1, 1 resimden 1.
    • Lay the device on its back, and rotate so the base is facing away from you.
  2. Ceiva LF2003 Power Supply Board Replacement: adım 2, 1 resimden 1.
    • Grip the frame with your fingers under the edge of the frame, and thumbs pushing down on the front of the device.
  3. Ceiva LF2003 Power Supply Board Replacement: adım 3, 1 resimden 1.
    • Lift up the frame with your fingers and push down the rest of the device with your thumbs.
  4. Ceiva LF2003 Power Supply Board Replacement: adım 4, 1 resimden 1.
    • Remove the frame and matte from the device.
  5. Ceiva LF2003 Power Supply Board Replacement, Internal Plastic Screen Frame: adım 5, 1 resimden 1.
    • Remove the four 7mm Torx T6 screws.
  6. Ceiva LF2003 Power Supply Board Replacement: adım 6, 2 resimden 1. Ceiva LF2003 Power Supply Board Replacement: adım 6, 2 resimden 2.
    • Using the plastic opening tool or your fingers, lift up the frame from any edge.
    • Remove the frame from the device.
  7. Ceiva LF2003 Power Supply Board Replacement, Display: adım 7, 3 resimden 1. Ceiva LF2003 Power Supply Board Replacement, Display: adım 7, 3 resimden 2. Ceiva LF2003 Power Supply Board Replacement, Display: adım 7, 3 resimden 3.
    • Unplug the cable connecting the display to the power supply using the flat end of the spudger to pry the connector away from the circuit board.
    • Alternate applying pressure to the left and right side of the connector to ensure that it does not break.
  8. Ceiva LF2003 Power Supply Board Replacement: adım 8, 1 resimden 1.
  9. Ceiva LF2003 Power Supply Board Replacement: adım 9, 2 resimden 1. Ceiva LF2003 Power Supply Board Replacement: adım 9, 2 resimden 2.
    • Lift up the display from the left edge and flip display over.
    • Do not lift the display too quickly, as the display is still connected to the main circuit board on the right.
  10. Ceiva LF2003 Power Supply Board Replacement: adım 10, 3 resimden 1. Ceiva LF2003 Power Supply Board Replacement: adım 10, 3 resimden 2. Ceiva LF2003 Power Supply Board Replacement: adım 10, 3 resimden 3.
    • Use the spudger to disconnect the ribbon cable from the display by the black pins away from the connector. There is a pin on either side of the connector.
    • Once both pins are released, the ribbon cable should slide easily out.
    • It may be easier if someone else holds the display so the cable does not get ripped out.
  11. Ceiva LF2003 Power Supply Board Replacement: adım 11, 1 resimden 1.
    • Remove the display assembly from the device.
  12. Ceiva LF2003 Power Supply Board Replacement, Power Supply Board: adım 12, 1 resimden 1.
  13. Ceiva LF2003 Power Supply Board Replacement: adım 13, 2 resimden 1. Ceiva LF2003 Power Supply Board Replacement: adım 13, 2 resimden 2.
    • Desolder the 3 wires attached to the board.
    • Remove the power supply board from the device.
    • The wires shown were not actually desoldered, but the board will now be separated from the rest of the device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Casey Glasgow
510 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 9-25, Maness Winter 2014 Cal Poly, Team 9-25, Maness Winter 2014 üyesi
CPSU-MANESS-W14S9G25
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 170
