Ana içeriğe geç
Celestron 71328 Nature DX 8x25 Control Arm Replacement
Neye ihtiyacın var
  1. Celestron 71328 Nature DX 8x25 Control Arm Replacement, Skin Cover: adım 1, 2 resimden 1. Celestron 71328 Nature DX 8x25 Control Arm Replacement, Skin Cover: adım 1, 2 resimden 2.
    • Using a plastic opening tool, nylon spudger or metal spudger, pry into seam of the skin cover at the center of the device. Lightly lift the tool which should cause the skin cover to rise.
  2. Celestron 71328 Nature DX 8x25 Control Arm Replacement: adım 2, 2 resimden 1. Celestron 71328 Nature DX 8x25 Control Arm Replacement: adım 2, 2 resimden 2.
    • Start peeling the skin away from the center. Apply force as there is an adhesive substance that is binding the skin to the device. Continue peeling until skin cover slides off completely.
  3. Celestron 71328 Nature DX 8x25 Control Arm Replacement: adım 3, 1 resimden 1.
    • Repeat steps 1 and 2 for the other side.
  4. Celestron 71328 Nature DX 8x25 Control Arm Replacement, Control Arm: adım 4, 2 resimden 1. Celestron 71328 Nature DX 8x25 Control Arm Replacement, Control Arm: adım 4, 2 resimden 2.
    • Locate the panels in front of the binoculars between the middle axle and the viewing lens and simply pry them off with your fingers
  5. Celestron 71328 Nature DX 8x25 Control Arm Replacement: adım 5, 2 resimden 1. Celestron 71328 Nature DX 8x25 Control Arm Replacement: adım 5, 2 resimden 2.
    • Using a flathead screwdriver, unscrew the highlighted screwhead for the control arm.
    • With your fingers, grab the screw head and pull it out completely once it's unscrewed and replace it with the new control arm if needed.
    • Parts revealed will be heavily lubricated. Consider wearing gloves.
Sonuç
Bryce Colangelo
525 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S6-G6, Lacy Spring 2017 USF Tampa, Team S6-G6, Lacy Spring 2017 üyesi
USFT-LACY-S17S6G6
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 5
Her zaman: 269
