Ana içeriğe geç
Cen-Tech Seven Function Digital Multimeter Ball Bearings Replacement
Neye ihtiyacın var
  1. Cen-Tech Seven Function Digital Multimeter Ball Bearings Replacement, Position Device: adım 1, 1 resimden 1.
    • Place the meter face down, and the back panel and screws can be seen.
    FixBot'a Sor
    Yorum Ekle
  2. Cen-Tech Seven Function Digital Multimeter Ball Bearings Replacement, Remove Back Panel Screws: adım 2, 2 resimden 1. Cen-Tech Seven Function Digital Multimeter Ball Bearings Replacement, Remove Back Panel Screws: adım 2, 2 resimden 2.
    • Unscrew the two 9mm screws on the back panel using a #0 Phillips screwdriver.
    FixBot'a Sor
    Yorum Ekle
  3. Cen-Tech Seven Function Digital Multimeter Ball Bearings Replacement, Remove Back Panel: adım 3, 1 resimden 1.
    • Remove the back panel of the device by lifting upward.
    • Remove the battery from the meter before continuing.
    FixBot'a Sor
    Yorum Ekle
  4. Cen-Tech Seven Function Digital Multimeter Ball Bearings Replacement, Unscrew Motherboard: adım 4, 2 resimden 1. Cen-Tech Seven Function Digital Multimeter Ball Bearings Replacement, Unscrew Motherboard: adım 4, 2 resimden 2.
    • Remove the four 7mm Phillips screws holding the circuit board in place.
    FixBot'a Sor
    Yorum Ekle
  5. Cen-Tech Seven Function Digital Multimeter Ball Bearings Replacement, Remove Motherboard: adım 5, 1 resimden 1.
    • Gently lift the circuit board away from the device casing.
    • Remove the battery after removing the back cover to reduce the chances of short-circuiting the circuit board.
    FixBot'a Sor
    Yorum Ekle
  6. Cen-Tech Seven Function Digital Multimeter Ball Bearings Replacement, Locate Dial: adım 6, 1 resimden 1.
    • The dial is located in the central part of the device.
    FixBot'a Sor
    Yorum Ekle
  7. Cen-Tech Seven Function Digital Multimeter Ball Bearings Replacement, Remove Dial: adım 7, 1 resimden 1.
    • Carefully remove dial from device by lifting upward.
    • Clean existing dial or replace if necessary.
    • Take care not to lose the small ball bearings.
    FixBot'a Sor
    Yorum Ekle
  8. Cen-Tech Seven Function Digital Multimeter Ball Bearings Replacement, Locate and Remove Ball Bearings: adım 8, 1 resimden 1.
    • Locate ball bearings. Carefully remove.
    • If both ball bearings are still present, try lubricating ball bearings with multi-use lubricant.
    • If one or both ball bearings are missing, simply replace.
    FixBot'a Sor
    Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Anna Kihm
965 İtibar
5 adet Kılavuz yazıldı
Ekip
Clemson, Team 2-4, Benson Fall 2014 Clemson, Team 2-4, Benson Fall 2014 üyesi
CLEM-BENSON-F14S2G4
4 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 24
Her zaman: 2,791
