Ana içeriğe geç
Cen-Tech Seven Function Digital Multimeter Circuit Board Replacement
Neye ihtiyacın var
  1. Cen-Tech Seven Function Digital Multimeter Circuit Board Replacement, Position Device: adım 1, 1 resimden 1.
    • Place the meter face down, and the back panel and screws can be seen.
  2. Cen-Tech Seven Function Digital Multimeter Circuit Board Replacement, Remove Back Panel Screws: adım 2, 2 resimden 1. Cen-Tech Seven Function Digital Multimeter Circuit Board Replacement, Remove Back Panel Screws: adım 2, 2 resimden 2.
    • Unscrew the two 9mm screws on the back panel using a #0 Phillips screwdriver.
  3. Cen-Tech Seven Function Digital Multimeter Circuit Board Replacement, Remove Back Panel: adım 3, 1 resimden 1.
    • Remove the back panel of the device by lifting upward.
    • Remove the battery from the meter before continuing.
  4. Cen-Tech Seven Function Digital Multimeter Circuit Board Replacement, Unscrew Motherboard: adım 4, 2 resimden 1. Cen-Tech Seven Function Digital Multimeter Circuit Board Replacement, Unscrew Motherboard: adım 4, 2 resimden 2.
    • Remove the four 7mm Phillips screws holding the circuit board in place.
  5. Cen-Tech Seven Function Digital Multimeter Circuit Board Replacement, Remove Motherboard: adım 5, 1 resimden 1.
    • Gently lift the circuit board away from the device casing.
    • Remove the battery after removing the back cover to reduce the chances of short-circuiting the circuit board.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Anna Kihm
956 İtibar
5 adet Kılavuz yazıldı
Ekip
Clemson, Team 2-4, Benson Fall 2014 Clemson, Team 2-4, Benson Fall 2014 üyesi
CLEM-BENSON-F14S2G4
4 Üyeler
6 adet Kılavuz yazıldı
1Rehber Yorum
What is the little dial on the circuit board on the upper right that has numbers 1 through 3 on it and it can be adjusted thank you
Thomas Clawson - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 16
Her zaman: 2,857
