Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
Giriş
Substitution of a broken Screen model ED060XG1 (LF) T1-11
I've found it for 23€ at https://es.aliexpress.com/item/Nuevo-E-t...
  1. This operation has to be made really carefully not to break the infrared guide located underneath the top cover The guide is a plastic frame. It's used to direct the IR beams that detect the position of the fingers. If it breaks it's posible that the touch of the display stops working The IR guide it's located between the frame and the display and it's glued with double sided tape. View picture
    • This operation has to be made really carefully not to break the infrared guide located underneath the top cover
    • The guide is a plastic frame. It's used to direct the IR beams that detect the position of the fingers. If it breaks it's posible that the touch of the display stops working
    • The IR guide it's located between the frame and the display and it's glued with double sided tape. View picture
    • To detach the frame you have to introduce a thin business card in between really carefully
    • Go all around the sides, being extra cautious with the bottom side not to go all the way to the central button
    • Take off the cover
  2. Unscrew the 4 screws shown in the picture
    • Unscrew the 4 screws shown in the picture
  3. Nintendo Switch Kit'leri
    Oyuna geri dönmek için hızlı bir düzeltme
    Switch Kit'leri Satın Al
  4. Unscrew the screws shown in the picture
    • Unscrew the screws shown in the picture
    • Slide a business card between the guide and the Screen to separate the double sided tape
    • Disconnect the battery first. You have to push the connector up as shown in the video
    • To loosen the screen, you have to lift the latch of the connectors as shown in the video
    • The screen is glued with double sided tape to the metal plate
    • Use the business card bellow the screen to unstick it from the double sided tape
  5. Here you can se, from left to right: Frame, Bottom Cover, IR Guide, Main Board and Screen.
    • Here you can se, from left to right: Frame, Bottom Cover, IR Guide, Main Board and Screen.
  6. It's important to stick the IR Guide to the new Screen before sticking it to the metal plate, the IR guide it's useful to center the screen Due to the position of the IR Guide it's critical, I replace the double sided tape that sticks together the screen and the IR Guide for a new strip of double sided tape Next, I stick the IR Guide to the screen
    • It's important to stick the IR Guide to the new Screen before sticking it to the metal plate, the IR guide it's useful to center the screen
    • Due to the position of the IR Guide it's critical, I replace the double sided tape that sticks together the screen and the IR Guide for a new strip of double sided tape
    • Next, I stick the IR Guide to the screen
Sonuç
To reassemble the device, follow this instructions in the reverse order.
Bu çevirmenlere özel teşekkürler:
100%
Jeronimo Bianco dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
Jesus Alfonso
1 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 42
Her zaman: 829
