Ana içeriğe geç
Change the thermal breaker - Sterwins HC 150 Bars Cleaner
Neye ihtiyacın var
  1. Change the thermal breaker - Sterwins HC 150 Bars Cleaner, Removing the reel handle: adım 1, 2 resimden 1. Change the thermal breaker - Sterwins HC 150 Bars Cleaner, Removing the reel handle: adım 1, 2 resimden 2.
    • Before working on the device, make sure that the power plug is unplugged.
    • Pull the handle of the reel facing you to unclip it.
  2. Change the thermal breaker - Sterwins HC 150 Bars Cleaner, Removal of the reel: adım 2, 3 resimden 1. Change the thermal breaker - Sterwins HC 150 Bars Cleaner, Removal of the reel: adım 2, 3 resimden 2. Change the thermal breaker - Sterwins HC 150 Bars Cleaner, Removal of the reel: adım 2, 3 resimden 3.
    • Unscrew the 2 fixing screws of the housing
    • Remove the housing
    • Using a flathead screwdriver, remove the clip that holds the high pressure outlet fitting from the pump to the reel.
  3. Change the thermal breaker - Sterwins HC 150 Bars Cleaner, Extraction of the reel: adım 3, 3 resimden 1. Change the thermal breaker - Sterwins HC 150 Bars Cleaner, Extraction of the reel: adım 3, 3 resimden 2. Change the thermal breaker - Sterwins HC 150 Bars Cleaner, Extraction of the reel: adım 3, 3 resimden 3.
    • Pull the connection facing you
    • Spread the 2 retaining bearings of the reel outwards.
    • Then remove the reel one side at a time.
  4. Change the thermal breaker - Sterwins HC 150 Bars Cleaner, Removal of the front panel: adım 4, 3 resimden 1. Change the thermal breaker - Sterwins HC 150 Bars Cleaner, Removal of the front panel: adım 4, 3 resimden 2. Change the thermal breaker - Sterwins HC 150 Bars Cleaner, Removal of the front panel: adım 4, 3 resimden 3.
    • Unscrew the 6 fixing screws marked with arrows.
    • Tilt the device on the front to access the last 2 fastening screws located under the product marked with arrows.
    • Then lay the device flat, and unscrew the plastic nut from the water inlet pipe.
  5. Change the thermal breaker - Sterwins HC 150 Bars Cleaner, Uncoupling of the front panel: adım 5, 3 resimden 1. Change the thermal breaker - Sterwins HC 150 Bars Cleaner, Uncoupling of the front panel: adım 5, 3 resimden 2. Change the thermal breaker - Sterwins HC 150 Bars Cleaner, Uncoupling of the front panel: adım 5, 3 resimden 3.
    • Remove the front panel upwards.
    • Return the product to its vertical position on its wheels.
    • Unscrew the screw indicated by the arrow to release the bearing from the reel to remove the pump outlet hose.
  6. Change the thermal breaker - Sterwins HC 150 Bars Cleaner, Uncoupling of the reel bearing: adım 6, 3 resimden 1. Change the thermal breaker - Sterwins HC 150 Bars Cleaner, Uncoupling of the reel bearing: adım 6, 3 resimden 2. Change the thermal breaker - Sterwins HC 150 Bars Cleaner, Uncoupling of the reel bearing: adım 6, 3 resimden 3.
    • With the mounting screw removed, slide the bearing as indicated by the arrow.
    • Then pull up to remove the bearing from the pipe.
    • Then remove the front panel.
  7. Change the thermal breaker - Sterwins HC 150 Bars Cleaner, Access to the On/Off switch: adım 7, 3 resimden 1. Change the thermal breaker - Sterwins HC 150 Bars Cleaner, Access to the On/Off switch: adım 7, 3 resimden 2. Change the thermal breaker - Sterwins HC 150 Bars Cleaner, Access to the On/Off switch: adım 7, 3 resimden 3.
    • Remove the button facing you.
    • Unscrew the 2 screws as indicated in order to disengage the support.
    • Then unscrew the 6 screws and remove the cover to access the electrical connection.
  8. Change the thermal breaker - Sterwins HC 150 Bars Cleaner, Electrical disconnection: adım 8, 3 resimden 1. Change the thermal breaker - Sterwins HC 150 Bars Cleaner, Electrical disconnection: adım 8, 3 resimden 2. Change the thermal breaker - Sterwins HC 150 Bars Cleaner, Electrical disconnection: adım 8, 3 resimden 3.
    • Remove the switch from its housing.
    • Disconnect the red power cable from the On/Off switch
  9. Change the thermal breaker - Sterwins HC 150 Bars Cleaner, Replacement of the circuit breaker: adım 9, 1 resimden 1.
    • Insert a breaker.
Bitiş Çizgisi
Bu çevirmenlere özel teşekkürler:
fr en
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
iRobot
1 İtibar
636 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 25
Her zaman: 299
