Giriş
Sometimes a tire becomes so damaged that it is no longer safe to drive with it on the car. This guide will show you how to put a new tire on your Jeep Wrangler.
Neye ihtiyacın var
(Picture 2, view from rear bumper) Open the trunk and remove the trunk's carpeting by simply reaching underneath and pulling up. The tools needed for changing a spare tire are located underneath the carpeting. Take out the following tools:
The jack, which is used to lift the car (top of picture 3)
The jack handle driver and its extension rod, which are used to turn the clasp (middle of picture 3)
A lug wrench, which is used to release lug nuts on the hubcap (bottom of picture 3)
To reassemble your device, follow these instructions in reverse order using the spare tire in place of the flat tire and the flat tire in place of the spare tire on the back of your Jeep.
3 farklı kişi bu kılavuzu tamamladı.
