Neye ihtiyacın var
Check that the position of the reverse handle is on 'OFF'
Using a small flat screwdriver, unclip the access cover to the screw that holds it in place.
Using a Phillips screwdriver, unscrew the fixing screw of the handle.
Using a 24 flat wrench, unscrew the nut counterclockwise.
Remove the inverter.
Replacing the inverter
Please make sure to properly align the pin of the diverter with the notch indicated by the arrow in the body of the faucet.
Insert the diverter into the body of the faucet.
Hand-tighten the inverter mounting nut clockwise.
Finish tightening using the 24mm wrench.
Align the reference point of the faucet body with the "OFF" marking on the handle.
Tighten the fixing screw of the handle using a Phillips screwdriver in a clockwise direction.
Put the cover back in place.
2 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
