Ana içeriğe geç
Char-Broil Grill Burner Replacement
Neye ihtiyacın var
  1. Char-Broil Grill Burner Replacement, Propane Heating Element: adım 1, 1 resimden 1.
    • This is an exterior shot of the camping stove.
    • Make sure that you're in a well lit area with towels under the stove to catch any dislodged residue.
  2. Char-Broil Grill Burner Replacement: adım 2, 2 resimden 1. Char-Broil Grill Burner Replacement: adım 2, 2 resimden 2.
    • Remove the lid by pulling straight up on its attached handle.
    • Next remove the top grill grate.
    • Grab one side of the grate.
    • Pull up on that side till you can get your hand under the edge.
    • Using both hands fully remove the grate.
  3. Char-Broil Grill Burner Replacement: adım 3, 1 resimden 1.
    • Remove the heat distribution plate.
    • Place a hand on either side of the heat distribution plate and pull up.
    • The plate should pull straight out of the grill.
  4. Char-Broil Grill Burner Replacement: adım 4, 2 resimden 1. Char-Broil Grill Burner Replacement: adım 4, 2 resimden 2.
    • Turn the stove on its side so that the bottom is easily accessible.
    • There is a single Phillips Head screw to remove in the center of the stove's bottom.
    • Fully remove this screw to detach the heating element from the main stove body.
  5. Char-Broil Grill Burner Replacement: adım 5, 1 resimden 1.
    • Turn the stove back onto its legs after removing the bottom screw holding it.
  6. Char-Broil Grill Burner Replacement: adım 6, 3 resimden 1. Char-Broil Grill Burner Replacement: adım 6, 3 resimden 2. Char-Broil Grill Burner Replacement: adım 6, 3 resimden 3.
    • Before you can remove the heating element full you need to unscrew the propane vale on the exterior of the stove.
    • Pull up on the heating element, it should be free floating.
    • After the propane valve is unscrewed lift the old heating element out of the stove and replace it with the new part.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Dan
155 İtibar
1 Kılavuz yazıldı
Ekip
Michigan Tech, Team S5-G1, Galliah Fall 2017 Michigan Tech, Team S5-G1, Galliah Fall 2017 üyesi
MTU-GALLIAH-F17S5G1
3 Üyeler
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 36
Her zaman: 709
