Giriş
You will need to have a replacement propane heating element for your Char-Broil Grill on hand before starting this replacement guide. When the heating element on the Char-Broil Grill begins to rust, the holes on the heating element grow larger as the metal rusts off. This makes the heat inconsistent and can cause other, further damage to the grill, making this replacement necessary.
Before you can remove the heating element full you need to unscrew the propane vale on the exterior of the stove.
Pull up on the heating element, it should be free floating.
After the propane valve is unscrewed lift the old heating element out of the stove and replace it with the new part.
2 farklı kişi bu kılavuzu tamamladı.
