Neye ihtiyacın var
Remove both T3 screws
Slide off the plastic piece by lifting out and then up
Slide plastic and spring assembly off the rail
Heat the glass screen with a blowdryer to soften the adhesives
Insert a razor blade between the glass and the body
Keep going around the rim of the display until loose
Disconnect vibrator motor
Disconnect heartrate and charging connector
Remove altimeter
Remove motherboard
It seems as if the heart rate sensor and charging pins are molded into the case, and I was not able to remove them
4 farklı kişi bu kılavuzu tamamladı.
12Kılavuz Yorumları
The tear down pictures are great, but in my Charge 3 I needed a T-1 and a T-2 driver
Same, my ifixit pro kit only had a driver for the external screws and did not come with a small enough driver to remove the screws inside the charge 3 unit. I'll need to get the smaller bit from a different kit.
Which step in the teardown guide needed the T1 driver?
This tear down was very easy to follow. The heart rate monitor was also sealed in with some adhesive for me too but a little heat gun took it right off. I had suspected water leaked in and that in fact was the culprit after inspecting the connection. corrosion all around the HR monitor.
