Ana içeriğe geç
Charging System reset
Neye ihtiyacın var
  1. Charging System reset, Flip over Roomba: adım 1, 1 resimden 1.
    • Flip over Roomba
  2. Charging System reset, Remove the battery: adım 2, 3 resimden 1. Charging System reset, Remove the battery: adım 2, 3 resimden 2. Charging System reset, Remove the battery: adım 2, 3 resimden 3.
    • Depress the tabs on the sides of the battery and lift it out.
    • You may need to use descent force when lifting up.
  3. Charging System reset, Reset the roomba: adım 3, 2 resimden 1. Charging System reset, Reset the roomba: adım 3, 2 resimden 2.
    • Flip Roomba back over
    • Hold down Roomba's power button for 15 seconds.
  4. Charging System reset, Reinstall the battery.: adım 4, 3 resimden 1. Charging System reset, Reinstall the battery.: adım 4, 3 resimden 2. Charging System reset, Reinstall the battery.: adım 4, 3 resimden 3.
    • Flip Roomba back over.
    • Reinsert the battery.
    • Flip Roomba over again.
  5. Charging System reset, Charge and run Roomba: adım 5, 1 resimden 1.
    • Charge Roomba for 16 hours and run on MAX cycle.
    • You should be done!
Sonuç
Perform an uninterrupted 16 hour charge. Then run on MAX cleaning cycle.
Austin Walter
1.055 İtibar
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 8
Her zaman: 198
