Ana içeriğe geç
Chef's Choice M115 Linkage Pins Replacement
Neye ihtiyacın var
  1. Chef's Choice M115 Linkage Pins Replacement, Case: adım 1, 2 resimden 1. Chef's Choice M115 Linkage Pins Replacement, Case: adım 1, 2 resimden 2.
    • Remove the two rubber feet on the motor side of the device.
    • Remove the five Phillips screws from the bottom of the case.
    • These screws are recessed deep in the device, so a long, thin screwdriver is required.
  2. Chef's Choice M115 Linkage Pins Replacement: adım 2, 1 resimden 1.
    • Remove the two hex-cap screws on the bottom using a pair of pliers.
  3. Chef's Choice M115 Linkage Pins Replacement: adım 3, 1 resimden 1.
    • Carefully flip the device right-side-up while grasping the top and bottom pieces.
    • The white cover should lift off with no resistance. If it does not, ensure all screws were removed in previous step.
  4. Chef's Choice M115 Linkage Pins Replacement: adım 4, 1 resimden 1.
    • Remove the sharpener guard by gently pulling up on it.
    • If the sharpener guard does not come off easily, ensure all screws were removed in step 1.
  5. Chef's Choice M115 Linkage Pins Replacement, Grinding Disc Linkage Pins: adım 5, 1 resimden 1.
    • Remove the motor and shaft assembly from the bottom of the case housing.
  6. Chef's Choice M115 Linkage Pins Replacement: adım 6, 2 resimden 1. Chef's Choice M115 Linkage Pins Replacement: adım 6, 2 resimden 2.
    • Use a screwdriver to push the pin out of the rod.
    • Use pliers to pull the pin the rest of the way out.
Sonuç
Bir başkası bu kılavuzu tamamladı.
James Herin
128 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team 3-3, Harley Fall 2015 IUPUI, Team 3-3, Harley Fall 2015 üyesi
IUPUI-HARLEY-F15S3G3
5 Üyeler
12 adet Kılavuz yazıldı
Bir Yorum
Where would you obtain new linkage pins. Can I use a similar gauged wire? What, and where can I find a suitable replacement?
Josh Brown - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 18
Her zaman: 1,752
