Ana içeriğe geç
Chef's Choice M115 Power Switch Replacement
Neye ihtiyacın var
    1. Chef's Choice M115 Power Switch Replacement, Case: adım 1, 2 resimden 1. Chef's Choice M115 Power Switch Replacement, Case: adım 1, 2 resimden 2.
      • Remove the two rubber feet on the motor side of the device.
      • Remove the five Phillips screws from the bottom of the case.
      • These screws are recessed deep in the device, so a long, thin screwdriver is required.
      FixBot'a Sor
      Yorum Ekle
    2. Chef's Choice M115 Power Switch Replacement: adım 2, 1 resimden 1.
      • Remove the two hex-cap screws on the bottom using a pair of pliers.
      FixBot'a Sor
      Yorum Ekle
    3. Chef's Choice M115 Power Switch Replacement: adım 3, 1 resimden 1.
      • Carefully flip the device right-side-up while grasping the top and bottom pieces.
      • The white cover should lift off with no resistance. If it does not, ensure all screws were removed in previous step.
      FixBot'a Sor
      Yorum Ekle
    4. Chef's Choice M115 Power Switch Replacement: adım 4, 1 resimden 1.
      • Remove the sharpener guard by gently pulling up on it.
      • If the sharpener guard does not come off easily, ensure all screws were removed in step 1.
      FixBot'a Sor
      Yorum Ekle
    1. Chef's Choice M115 Power Switch Replacement, Power Switch: adım 5, 1 resimden 1.
      • Carefully lift the entire motor assembly out of the case.
      FixBot'a Sor
      Yorum Ekle
    2. Chef's Choice M115 Power Switch Replacement: adım 6, 2 resimden 1. Chef's Choice M115 Power Switch Replacement: adım 6, 2 resimden 2.
      • Using a screw driver, unclip the edges of the switch by pushing them inwards and nudging the switch out of the plastic casing. You will hear a click when the edges unhook from the casing.
      FixBot'a Sor
      Yorum Ekle
    3. Chef's Choice M115 Power Switch Replacement: adım 7, 2 resimden 1. Chef's Choice M115 Power Switch Replacement: adım 7, 2 resimden 2.
      • Remove the spade connectors from the switch by pulling only on the connector, not the wire.
      • This may require a fair bit of force. Use caution to not damage the device, yourself, or your surroundings.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Hatontola malawo
147 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team 3-3, Harley Fall 2015 IUPUI, Team 3-3, Harley Fall 2015 üyesi
IUPUI-HARLEY-F15S3G3
5 Üyeler
33 adet Kılavuz yazıldı
1Rehber Yorum
What kind of switch should I replace the bad switch with? Is there one on Amazon ?
Ryan Frawley - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 31
Her zaman: 702
