Giriş
If the sharpening stones become loose or do not apply the correct pressure to the knifes, this could be caused by either broken or missing linkage pins. These pins hold the sharpening stones in place on the motor axle. Replacing a broken or missing pin is a relatively easy process.
Neye ihtiyacın var
Remove the two rubber feet on the motor side of the device.
Remove the five Phillips screws from the bottom of the case.
Remove the motor and shaft assembly from the bottom of the case housing.
Bir başkası bu kılavuzu tamamladı.
Bir Yorum
Where would you obtain new linkage pins. Can I use a similar gauged wire? What, and where can I find a suitable replacement?
