Ana içeriğe geç
Chef's Choice M115 Power Cord Replacement
Neye ihtiyacın var
  1. Chef's Choice M115 Power Cord Replacement, Case: adım 1, 2 resimden 1. Chef's Choice M115 Power Cord Replacement, Case: adım 1, 2 resimden 2.
    • Remove the two rubber feet on the motor side of the device.
    • Remove the five Phillips screws from the bottom of the case.
    • These screws are recessed deep in the device, so a long, thin screwdriver is required.
    FixBot'a Sor
  2. Chef's Choice M115 Power Cord Replacement: adım 2, 1 resimden 1.
    • Remove the two hex-cap screws on the bottom using a pair of pliers.
    FixBot'a Sor
  3. Chef's Choice M115 Power Cord Replacement: adım 3, 1 resimden 1.
    • Carefully flip the device right-side-up while grasping the top and bottom pieces.
    • The white cover should lift off with no resistance. If it does not, ensure all screws were removed in previous step.
    FixBot'a Sor
  4. Chef's Choice M115 Power Cord Replacement: adım 4, 1 resimden 1.
    • Remove the sharpener guard by gently pulling up on it.
    • If the sharpener guard does not come off easily, ensure all screws were removed in step 1.
    FixBot'a Sor
  5. Chef's Choice M115 Power Cord Replacement, Power Cord: adım 5, 2 resimden 1. Chef's Choice M115 Power Cord Replacement, Power Cord: adım 5, 2 resimden 2.
    • Carefully lift the entire motor assembly out of the case.
    FixBot'a Sor
  6. Chef's Choice M115 Power Cord Replacement: adım 6, 1 resimden 1.
    • Remove the spade connectors from the switch by pulling only on the connector, not the wire.
    • These should come off without tools, but will require a fair bit of force. Mark each wire with tape if you are unsure of the wiring layout of the device.
    FixBot'a Sor
  7. Chef's Choice M115 Power Cord Replacement: adım 7, 1 resimden 1.
    • Disconnect the spade connector on the motor by pulling only on the connector, not the cord.
    FixBot'a Sor
Sonuç
To reassemble your device, follow these instructions in reverse order. Take care to ensure the power connections are connected back to their original location.
Bir başkası bu kılavuzu tamamladı.
Zachary Grounds
580 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team 3-3, Harley Fall 2015 IUPUI, Team 3-3, Harley Fall 2015 üyesi
IUPUI-HARLEY-F15S3G3
5 Üyeler
14 adet Kılavuz yazıldı
1Rehber Yorum
I cannot find a replacement cord with the molded part that passes through the case. Is this something common (from hardware store), or do I need to find a part from the manufacturer?
Luke Shingledecker - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 63
Her zaman: 852
