Giriş
Sharpening is essentially what the chef's choice is about. This is achieved by the sharpening stones and will frequently need to be replaced. Extra caution to be taken on the removal of the c-clips as they can easily spring out and get lost.
Neye ihtiyacın var
Remove the two rubber feet on the motor side of the device.
Remove the five Phillips screws from the bottom of the case.
With the outer case removed, firmly grasp the motor-axle attachment and remove it from the base. It should come right off of the assembly.
2 farklı kişi bu kılavuzu tamamladı.
4 Yorum
where does one get the replacement stones. im not seeing they in my amazon/google searches. also cant seem to see them on manufacturers website section for parts.
I have the same question.
same question, where do I order replacement stones ?? I have the chef’s choice Sportsman from cabelas, thanks in advance .. you can send any info to my e-mail thebobster@ns.sympatico.ca any info wiuld be greatly appreciated..
