Ana içeriğe geç
Chefman RJ38-V2-35 Power Cord Replacement
Neye ihtiyacın var
  1. Chefman RJ38-V2-35 Power Cord Replacement, Power Cord: adım 1, 1 resimden 1.
    • Please be sure that the device is unplugged and remove the frying basket from the device.
    • Check the power cord for frays or cracks
  2. Chefman RJ38-V2-35 Power Cord Replacement: adım 2, 2 resimden 1. Chefman RJ38-V2-35 Power Cord Replacement: adım 2, 2 resimden 2.
    • If the cord appears to be fine, orient your device upside down so that the temperature knob is on the bottom and the power cord area is facing you.
    • Place your hand firmly on the device to prevent slippage.
    • Using the Phillips #1 screwdriver, remove the two 4 mm screws found at each corner of the bottom panel.
  3. Chefman RJ38-V2-35 Power Cord Replacement: adım 3, 2 resimden 1. Chefman RJ38-V2-35 Power Cord Replacement: adım 3, 2 resimden 2.
    • After removing the two screws on the bottom, remove the four 6mm screws located on the white tabs that are securing the power cord.
    • Once the white tabs come off, the power cord will be more visible, the white wire is connected with the blue wire, while the black wire is connected with the red wire.
  4. Chefman RJ38-V2-35 Power Cord Replacement: adım 4, 2 resimden 1. Chefman RJ38-V2-35 Power Cord Replacement: adım 4, 2 resimden 2.
    • Use a pair of scissor, cut off any secure wire attachments, such as the white capsule.
    • The wire will come apart and you can now separate the power cord from the device’s wires.
    • The red and blue wires of the device will show it’s aluminum strips, this is what connect to the replacement wire.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
An L Duong
295 İtibar
1 Kılavuz yazıldı
Ekip
UW Tacoma, Team S1-G4, Rose Fall 2018 UW Tacoma, Team S1-G4, Rose Fall 2018 üyesi
UWT-ROSE-F18S1G4
4 Üyeler
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 23
Son 30 gün: 101
Her zaman: 6,739
