Ana içeriğe geç
Chefman RJ38-V2-35 Repair Temperature Knob Replacement
Neye ihtiyacın var
  1. Chefman RJ38-V2-35 Repair Temperature Knob  Replacement, Temperature Knob: adım 1, 1 resimden 1.
    • Please be sure that the device is unplugged and remove the frying basket from the device.
    • Orient your device where the both the timer knob and temperature knob are facing you.
    • Slide the plastic opening tool under the temperature knob to lift it up.
    • You can slide your fingers in between the gap and take the temperature knob off.
  2. Chefman RJ38-V2-35 Repair Temperature Knob  Replacement: adım 2, 1 resimden 1.
    • Using the Phillips #1 screwdriver, remove the two 4mm screws found under the temperature knob.
    • Place you fingers under the silver top and firmly lift it up.
  3. Chefman RJ38-V2-35 Repair Temperature Knob  Replacement: adım 3, 3 resimden 1. Chefman RJ38-V2-35 Repair Temperature Knob  Replacement: adım 3, 3 resimden 2. Chefman RJ38-V2-35 Repair Temperature Knob  Replacement: adım 3, 3 resimden 3.
    • Using the Phillips #1 screwdriver, remove the two 3 mm screws found at the top of the black panel.
    • Pop off the top panel of the device with your fingers.
  4. Chefman RJ38-V2-35 Repair Temperature Knob  Replacement: adım 4, 1 resimden 1.
    • Using a pair of scissors, cut off the cable cord that is securing the wire cords.
  5. Chefman RJ38-V2-35 Repair Temperature Knob  Replacement: adım 5, 3 resimden 1. Chefman RJ38-V2-35 Repair Temperature Knob  Replacement: adım 5, 3 resimden 2. Chefman RJ38-V2-35 Repair Temperature Knob  Replacement: adım 5, 3 resimden 3.
    • Detach the device’s wires from the potentiometer.
  6. Chefman RJ38-V2-35 Repair Temperature Knob  Replacement: adım 6, 1 resimden 1.
    • Replace a new potentiometer to the device.
    • Attach the wires back to the new potentiometer.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Lucas Yi
156 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 37
Her zaman: 2,288
