Giriş
If the air fryer is not stopping at an allotted time for cooking, this guide is for you. This guide will work you through how to replace the timing system in the air fryer. It’s a semi long process, but not too challenging.
Neye ihtiyacın var
Using the plastic opening tool, pop off each of the four corners on the top silver plate.
Bir başkası bu kılavuzu tamamladı.
