Ana içeriğe geç
Chromebook Pixel (2013) Battery Replacement
Neye ihtiyacın var
  1. Chromebook Pixel (2013) Battery Replacement, Remove the rubber pads: adım 1, 2 resimden 1. Chromebook Pixel (2013) Battery Replacement, Remove the rubber pads: adım 1, 2 resimden 2.
    • Flip your Chromebook Pixel over onto its back
    • Using a flat edge screwdriver, gently pull up to remove the rubber pads from the laptop to reveal the screws
  2. Chromebook Pixel (2013) Battery Replacement, Removing the bottom panel: adım 2, 3 resimden 1. Chromebook Pixel (2013) Battery Replacement, Removing the bottom panel: adım 2, 3 resimden 2. Chromebook Pixel (2013) Battery Replacement, Removing the bottom panel: adım 2, 3 resimden 3.
    • Using a small Philips screwdriver, remove the four screws under the pads
    • Using a spudger (or another flat but slightly blunt object), gently pry the laptop open
    • You may find it helpful to start with a smaller (skinnier) head and work your way up to a larger size
  3. Chromebook Pixel (2013) Battery Replacement, Pop it open: adım 3, 2 resimden 1. Chromebook Pixel (2013) Battery Replacement, Pop it open: adım 3, 2 resimden 2.
    • Gently pull up from the front of the laptop and open it up like a clamshell
  4. Chromebook Pixel (2013) Battery Replacement, Remove the write protect screw (IF APPLICABLE): adım 4, 2 resimden 1. Chromebook Pixel (2013) Battery Replacement, Remove the write protect screw (IF APPLICABLE): adım 4, 2 resimden 2.
    • Locate the write protect screw
    • Remove it and you can begin flashing your BIOS!
  5. Chromebook Pixel (2013) Battery Replacement, Remove the bottom cover: adım 5, 1 resimden 1.
    • You should have your Chromebook Pixel flipped over and the bottom cover removed at this point
  6. Chromebook Pixel (2013) Battery Replacement, Release the battery: adım 6, 1 resimden 1.
    • Remove the screws holding the battery in place.
  7. Chromebook Pixel (2013) Battery Replacement, Unplug the battery: adım 7, 2 resimden 1. Chromebook Pixel (2013) Battery Replacement, Unplug the battery: adım 7, 2 resimden 2.
    • Using a splunger or your finger and a gentle pull, unplug the battery from the Pixel logic board
    • Pull the battery toward you to remove it
  8. Chromebook Pixel (2013) Battery Replacement, Examine the new battery: adım 8, 1 resimden 1.
    • Make sure that the wattage and voltage matches the values of the old battery
  9. Chromebook Pixel (2013) Battery Replacement, Install the new battery: adım 9, 2 resimden 1. Chromebook Pixel (2013) Battery Replacement, Install the new battery: adım 9, 2 resimden 2.
    • Follow these steps in reverse and turn on the Pixel.
    • If the old battery was failing, will have to reset the system time when you log back into Chrome OS or your installed Operating System
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Kevin Fessler
1.770 İtibar
4 adet Kılavuz yazıldı
2 Yorum
You can now find these batteries on Amazon too- just search for the same part number GP-S22-000000-0100
riansanderson - Yanıt
Hello could someone help
Where would i get a replacement battery from ? having trouble locating one .
Thanks in advance nick
Nick Harrisson - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 38
Her zaman: 7,088
