Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
If your battery is starting to go out here is a guide which will show you how to throw in a new one.
Parçalar
  1. Flip your Chromebook Pixel over onto its back Using a flat edge screwdriver, gently pull up to remove the rubber pads from the laptop to reveal the screws
    • Flip your Chromebook Pixel over onto its back
    • Using a flat edge screwdriver, gently pull up to remove the rubber pads from the laptop to reveal the screws
  2. Using a small Philips screwdriver, remove the four screws under the pads Using a spudger (or another flat but slightly blunt object), gently pry the laptop open You may find it helpful to start with a smaller (skinnier) head and work your way up to a larger size
    • Using a small Philips screwdriver, remove the four screws under the pads
    • Using a spudger (or another flat but slightly blunt object), gently pry the laptop open
    • You may find it helpful to start with a smaller (skinnier) head and work your way up to a larger size
  3. Gently pull up from the front of the laptop and open it up like a clamshell Gently pull up from the front of the laptop and open it up like a clamshell
    • Gently pull up from the front of the laptop and open it up like a clamshell
  4. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  5. Locate the write protect screw Remove it and you can begin flashing your BIOS!
    • Locate the write protect screw
    • Remove it and you can begin flashing your BIOS!
    Do I have to flash the bios when replacing the battery?
    Clive Gorman - Yanıt
    There is no need to flash the BIOS if all you want to do is replace the battery.
    Kevin Fessler -
    I want to install windows on to the chrome book pixel 2013 but i have concerns regarding the touch screen. Can you help? Is there any video that you have uploaded for the installation?
    Hari Krishna Bharadw Pudipeddi - Yanıt
  6. You should have your Chromebook Pixel flipped over and the bottom cover removed at this point
    • You should have your Chromebook Pixel flipped over and the bottom cover removed at this point
  7. Remove the screws holding the battery in place.
    • Remove the screws holding the battery in place.
  8. Using a splunger or your finger and a gentle pull, unplug the battery from the Pixel logic board Pull the battery toward you to remove it
    • Using a splunger or your finger and a gentle pull, unplug the battery from the Pixel logic board
    • Pull the battery toward you to remove it
  9. Make sure that the wattage and voltage matches the values of the old battery
    • Make sure that the wattage and voltage matches the values of the old battery
  10. Follow these steps in reverse and turn on the Pixel. If the old battery was failing, will have to reset the system time when you log back into Chrome OS or your installed Operating System
    • Follow these steps in reverse and turn on the Pixel.
    • If the old battery was failing, will have to reset the system time when you log back into Chrome OS or your installed Operating System
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Kevin Fessler
1.371 İtibar
4 adet Kılavuz yazıldı
2 Yorum
You can now find these batteries on Amazon too- just search for the same part number GP-S22-000000-0100
riansanderson - Yanıt
Hello could someone help
Where would i get a replacement battery from ? having trouble locating one .
Thanks in advance nick
Nick Harrisson - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 31
Son 30 gün: 86
Her zaman: 4,279
