Ana içeriğe geç
Chromebook x360 14-da0011dx Wireless Card Replacement
Neye ihtiyacın var
  1. Chromebook x360 14-da0011dx Wireless Card Replacement, Lower Case: adım 1, 1 resimden 1.
    • Flip the device over with the hinge facing away from you.
    • On the back of the device, remove the two rubber strips on the top and the bottom of the device using a spudger.
  2. Chromebook x360 14-da0011dx Wireless Card Replacement: adım 2, 2 resimden 1. Chromebook x360 14-da0011dx Wireless Card Replacement: adım 2, 2 resimden 2.
    • Remove the seven 8.0 mm screws located under the two rubber pads and the screws along the back of the device using a Phillips #1 screwdriver.
  3. Chromebook x360 14-da0011dx Wireless Card Replacement: adım 3, 3 resimden 1. Chromebook x360 14-da0011dx Wireless Card Replacement: adım 3, 3 resimden 2. Chromebook x360 14-da0011dx Wireless Card Replacement: adım 3, 3 resimden 3.
    • Use a spudger to gently pry the edges of the back cover off the device. Slowly work all the way around the device until the panel comes loose.
  4. Chromebook x360 14-da0011dx Wireless Card Replacement, Wireless card: adım 4, 1 resimden 1.
    • Remove the plastic protector from the top of the wires plugged into the wireless card.
  5. Chromebook x360 14-da0011dx Wireless Card Replacement: adım 5, 1 resimden 1.
    • Remove the single 3 mm screw holding down the wireless card with the Phillips #1 screwdriver.
  6. Chromebook x360 14-da0011dx Wireless Card Replacement: adım 6, 2 resimden 1. Chromebook x360 14-da0011dx Wireless Card Replacement: adım 6, 2 resimden 2.
    • Disconnect the antenna cables leading into the wireless card.
    • Slide the wireless card out of its port and lift it out of the device.
    • The cables are numbered with their corresponding port. Be careful not to damage the connections when reassembling during this step.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 17
Her zaman: 160
