Giriş
This guide provides instructions for replacing the Wireless card in your Chromebook x360 14-da0011dx. If you're having problems with Wi-Fi connections, reseating or replacing the wireless card may be necessary.
Neye ihtiyacın var
Flip the device over with the hinge facing away from you.
On the back of the device, remove the two rubber strips on the top and the bottom of the device using a spudger.
Remove the plastic protector from the top of the wires plugged into the wireless card.
Bir başkası bu kılavuzu tamamladı.
