Ana içeriğe geç
Chromecast Case Replacement
Neye ihtiyacın var
  1. Chromecast Case Replacement, Case: adım 1, 1 resimden 1.
    • Place the Google Chromecast face down (with text not showing) on a flat surface.
    • Insert a flat tool just above the micro-USB port to detach the top part of the case from the bottom.
  2. Chromecast Case Replacement: adım 2, 1 resimden 1.
    • Continue prying the top of the case from the bottom toward the HDMI port until the top casing is completely removed.
  3. Chromecast Case Replacement: adım 3, 1 resimden 1.
    • Remove the circuit board, lifting from the HDMI port.
    • The power button may become dislodged.
  4. Chromecast Case Replacement: adım 4, 1 resimden 1.
    • Pry the plastic clamp from the heatsink.
    • Do not pry too hard to avoid breaking the clamp.
  5. Chromecast Case Replacement: adım 5, 2 resimden 1. Chromecast Case Replacement: adım 5, 2 resimden 2.
    • Insert a plastic opening tool under the heatsink, and pry the heatsink up and out of the case.
    • The adhesive's strength may vary, and force should be applied gently until it becomes dislodged to avoid breaking the device.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Cameron Heiges
688 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team S5-G6, Baechle Spring 2018 IUPUI, Team S5-G6, Baechle Spring 2018 üyesi
IUPUI-BAECHLE-S18S5G6
3 Üyeler
6 adet Kılavuz yazıldı
1Rehber Yorum
que hacer si el pin de centro de carga se despredio como pegarlo o soldarlo?
edgar arreola - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 30
Her zaman: 1,806
