Ana içeriğe geç
Chromecast Metal Shielding Replacement
Neye ihtiyacın var
  1. Chromecast Metal Shielding Replacement, Case: adım 1, 1 resimden 1.
    • Place the Google Chromecast face down (with text not showing) on a flat surface.
    • Insert a flat tool just above the micro-USB port to detach the top part of the case from the bottom.
  2. Chromecast Metal Shielding Replacement: adım 2, 1 resimden 1.
    • Continue prying the top of the case from the bottom toward the HDMI port until the top casing is completely removed.
  3. Chromecast Metal Shielding Replacement: adım 3, 1 resimden 1.
    • Remove the circuit board, lifting from the HDMI port.
    • The power button may become dislodged.
  4. Chromecast Metal Shielding Replacement: adım 4, 1 resimden 1.
    • Pry the plastic clamp from the heatsink.
    • Do not pry too hard to avoid breaking the clamp.
  5. Chromecast Metal Shielding Replacement: adım 5, 2 resimden 1. Chromecast Metal Shielding Replacement: adım 5, 2 resimden 2.
    • Insert a plastic opening tool under the heatsink, and pry the heatsink up and out of the case.
    • The adhesive's strength may vary, and force should be applied gently until it becomes dislodged to avoid breaking the device.
  6. Chromecast Metal Shielding Replacement, Metal Shielding: adım 6, 1 resimden 1.
    • Pry the metal extensions from the HDMI port.
  7. Chromecast Metal Shielding Replacement: adım 7, 1 resimden 1.
    • Insert the plastic opening tool into the corner next to the metal extensions, prying upward.
  8. Chromecast Metal Shielding Replacement: adım 8, 1 resimden 1.
    • Pry the metal piece around the metal, extruding it from the internal components.
  9. Chromecast Metal Shielding Replacement: adım 9, 1 resimden 1.
    • Completely remove the top metal casing to expose the internal components.
  10. Chromecast Metal Shielding Replacement: adım 10, 1 resimden 1.
    • Pry metal extensions from the HDMI port on the posterior side of the device.
  11. Chromecast Metal Shielding Replacement: adım 11, 1 resimden 1.
    • Insert the plastic opening tool under the corner to pry off the metal casing from the internal components.
  12. Chromecast Metal Shielding Replacement: adım 12, 1 resimden 1.
    • Continue prying around the device, removing the metal piece from the internal components.
  13. Chromecast Metal Shielding Replacement: adım 13, 1 resimden 1.
    • Completely remove the bottom metal piece.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Cameron Heiges
688 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team S5-G6, Baechle Spring 2018 IUPUI, Team S5-G6, Baechle Spring 2018 üyesi
IUPUI-BAECHLE-S18S5G6
3 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 12
Son 30 gün: 49
Her zaman: 1,828
