Ana içeriğe geç
Chromecast Power Button Replacement
Neye ihtiyacın var
  1. Chromecast Power Button Replacement, Case: adım 1, 1 resimden 1.
    • Place the Google Chromecast face down (with text not showing) on a flat surface.
    • Insert a flat tool just above the micro-USB port to detach the top part of the case from the bottom.
    FixBot'a Sor
    Yorum Ekle
  2. Chromecast Power Button Replacement: adım 2, 1 resimden 1.
    • Continue prying the top of the case from the bottom toward the HDMI port until the top casing is completely removed.
    FixBot'a Sor
    Yorum Ekle
  3. Chromecast Power Button Replacement: adım 3, 1 resimden 1.
    • Remove the circuit board, lifting from the HDMI port.
    • The power button may become dislodged.
    FixBot'a Sor
    Yorum Ekle
  4. Chromecast Power Button Replacement: adım 4, 1 resimden 1.
    • Pry the plastic clamp from the heatsink.
    • Do not pry too hard to avoid breaking the clamp.
    FixBot'a Sor
    Yorum Ekle
  5. Chromecast Power Button Replacement: adım 5, 2 resimden 1. Chromecast Power Button Replacement: adım 5, 2 resimden 2.
    • Insert a plastic opening tool under the heatsink, and pry the heatsink up and out of the case.
    • The adhesive's strength may vary, and force should be applied gently until it becomes dislodged to avoid breaking the device.
    FixBot'a Sor
    Yorum Ekle
  6. Chromecast Power Button Replacement, Power Button: adım 6, 1 resimden 1.
    • Press the plastic button from the outside of the port, pushing it inward if it is stuck.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Cameron Heiges
688 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team S5-G6, Baechle Spring 2018 IUPUI, Team S5-G6, Baechle Spring 2018 üyesi
IUPUI-BAECHLE-S18S5G6
3 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 9
Son 30 gün: 23
Her zaman: 1,307
