Ana içeriğe geç
Chromo Inc. T2 Internal Speaker Replacement
Neye ihtiyacın var
  1. Chromo Inc. T2 Internal Speaker Replacement, Removing the Casing: adım 1, 3 resimden 1. Chromo Inc. T2 Internal Speaker Replacement, Removing the Casing: adım 1, 3 resimden 2. Chromo Inc. T2 Internal Speaker Replacement, Removing the Casing: adım 1, 3 resimden 3.
    • Using your Plastic Opening Tool, place it in between the screen and the case. Slowly move it around the casing while prying in a downward motion to undo the hinges holding the two together and separate the two parts.
  2. Chromo Inc. T2 Internal Speaker Replacement, Turn it around: adım 2, 1 resimden 1.
    • After separating the case and screen, turn your screen face down so you can see the internal parts!
  3. Chromo Inc. T2 Internal Speaker Replacement, Removing the Tape: adım 3, 3 resimden 1. Chromo Inc. T2 Internal Speaker Replacement, Removing the Tape: adım 3, 3 resimden 2. Chromo Inc. T2 Internal Speaker Replacement, Removing the Tape: adım 3, 3 resimden 3.
    • Remove two strips of tape: One holding down the wires and the other holding down the internal speaker.
  4. Chromo Inc. T2 Internal Speaker Replacement, Desoldering the Wires and Removing the Speaker: adım 4, 3 resimden 1. Chromo Inc. T2 Internal Speaker Replacement, Desoldering the Wires and Removing the Speaker: adım 4, 3 resimden 2. Chromo Inc. T2 Internal Speaker Replacement, Desoldering the Wires and Removing the Speaker: adım 4, 3 resimden 3.
    • Using a Soldering Iron, desolder both speaker wires. Once both wires are desoldered, your Internal Speaker is now ready for replacement!
    • Soldering Iron gets very hot, take care to not touch anywhere on the soldering iron except for the handle!
Sonuç
Ismael DeLuna
637 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 15-1, Watkins Winter 2015 USF Tampa, Team 15-1, Watkins Winter 2015 üyesi
USFT-WATKINS-W15S15G1
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 8
Her zaman: 216
