Ana içeriğe geç
Chromo Inc. T2 Motherboard Replacement
Neye ihtiyacın var
  1. Chromo Inc. T2 Motherboard Replacement, Removing the Casing: adım 1, 3 resimden 1. Chromo Inc. T2 Motherboard Replacement, Removing the Casing: adım 1, 3 resimden 2. Chromo Inc. T2 Motherboard Replacement, Removing the Casing: adım 1, 3 resimden 3.
    • Place your Plastic Opening Tool between the screen and the case. Slowly move it around the casing while prying in a downward motion to undo the hinges holding the two together and separate the two parts.
  2. Chromo Inc. T2 Motherboard Replacement, Turn it around: adım 2, 1 resimden 1.
    • After separating the case and screen, turn your screen face down so you can see the internal parts!
  3. Chromo Inc. T2 Motherboard Replacement, Disconnecting Flex Cables: adım 3, 2 resimden 1. Chromo Inc. T2 Motherboard Replacement, Disconnecting Flex Cables: adım 3, 2 resimden 2.
    • Peel back the tape holding the big flex cable in place.
    • Using your plastic opening tool, gently push back the gray connector to free the flex cables and then pull them out.
  4. Chromo Inc. T2 Motherboard Replacement, Disconnecting the Camera: adım 4, 2 resimden 1. Chromo Inc. T2 Motherboard Replacement, Disconnecting the Camera: adım 4, 2 resimden 2.
    • Using the small plastic opening tool, gently push the gray connector back to unlock the flex cable.
    • Using a pair of tweezers, gently grasp the flex cable and disconnect it from the connector.
  5. Chromo Inc. T2 Motherboard Replacement: adım 5, 2 resimden 1. Chromo Inc. T2 Motherboard Replacement: adım 5, 2 resimden 2.
    • Using a Phillips #00 Precision Screwdriver, remove the three 3mm screws holding the motherboard.
  6. Chromo Inc. T2 Motherboard Replacement: adım 6, 3 resimden 1. Chromo Inc. T2 Motherboard Replacement: adım 6, 3 resimden 2. Chromo Inc. T2 Motherboard Replacement: adım 6, 3 resimden 3.
    • Using your soldering iron, desolder the six wires on the side of the logic board.
    • Note: Remember where these wires go as re-connecting them incorrectly can lead to damaging the device!
    • Soldering Iron gets very hot, take care to not touch anywhere on the soldering iron except for the handle!
  7. Chromo Inc. T2 Motherboard Replacement: adım 7, 2 resimden 1. Chromo Inc. T2 Motherboard Replacement: adım 7, 2 resimden 2.
    • Using your soldering Iron, desolder the grounding cable on the motherboard.
  8. Chromo Inc. T2 Motherboard Replacement: adım 8, 1 resimden 1.
    • Your motherboard is now ready for replacement!
Sonuç
Ismael DeLuna
637 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 15-1, Watkins Winter 2015 USF Tampa, Team 15-1, Watkins Winter 2015 üyesi
USFT-WATKINS-W15S15G1
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 8
Her zaman: 640
