Ana içeriğe geç
Chromo Noria Camera Replacement
Neye ihtiyacın var
  1. Chromo Noria Camera  Replacement, Back Panel: adım 1, 3 resimden 1. Chromo Noria Camera  Replacement, Back Panel: adım 1, 3 resimden 2. Chromo Noria Camera  Replacement, Back Panel: adım 1, 3 resimden 3.
    • Insert your Plastic Opening Tool into the crease between the front panel and back panel.
    • Slide the Opening Tool around the entire device. As you progress, you should see the device open.
    FixBot'a Sor
    Yorum Ekle
  2. Chromo Noria Camera  Replacement: adım 2, 1 resimden 1.
    • Carefully turn the device over.
    • Lay the back panel aside so you can see the device's parts.
    FixBot'a Sor
    Yorum Ekle
  3. Chromo Noria Camera  Replacement, Camera: adım 3, 2 resimden 1. Chromo Noria Camera  Replacement, Camera: adım 3, 2 resimden 2.
    • Carefully detach one side of the black tape from the board.
    FixBot'a Sor
    Yorum Ekle
  4. Chromo Noria Camera  Replacement: adım 4, 2 resimden 1. Chromo Noria Camera  Replacement: adım 4, 2 resimden 2.
    • Using a small plastic opening tool, flip the black connector up until it makes "tick" sound.
    • Now, the flexing cable is ready to be removed.
    FixBot'a Sor
    Yorum Ekle
  5. Chromo Noria Camera  Replacement: adım 5, 2 resimden 1. Chromo Noria Camera  Replacement: adım 5, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Using a pair of tweezers, hold the flexing cable right below the black connector.
    • Gently pull the flexing cable out of the connector while balancing the other side of the device with another hand.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Ryan Rho
201 İtibar
2 adet Kılavuz yazıldı
Ekip
Baylor, Team 5-6, Williams Fall 2016 Baylor, Team 5-6, Williams Fall 2016 üyesi
BU-WILLIAMS-F16S5G6
3 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 21
Her zaman: 357
