Ana içeriğe geç
Chumby One Motherboard Replacement
Neye ihtiyacın var
  1. Chumby One Motherboard Replacement, Chassis: adım 1, 1 resimden 1.
    • Remove 4 self-adhesive plastic dots covering the screw holes.
  2. Chumby One Motherboard Replacement: adım 2, 1 resimden 1.
    • Remove the four 2mm screws with a Phillips screwdriver.
  3. Chumby One Motherboard Replacement: adım 3, 1 resimden 1.
    • Remove the back and bottom cover.
  4. Chumby One Motherboard Replacement: adım 4, 1 resimden 1.
    • Disconnect the battery connector from the motherboard with a plastic opening tool.
  5. Chumby One Motherboard Replacement: adım 5, 1 resimden 1.
    • Disconnect the microphone connector from the motherboard with a plastic opening tool.
  6. Chumby One Motherboard Replacement: adım 6, 1 resimden 1.
    • Remove the display ribbon cable from its socket with a plastic opening tool.
  7. Chumby One Motherboard Replacement: adım 7, 1 resimden 1.
    • Remove the volume knob from the side of the Chumby One with a plastic opening tool.
  8. Chumby One Motherboard Replacement: adım 8, 1 resimden 1.
    • Remove the four 6mm screws using a PH000 bit on the inner chassis.
  9. Chumby One Motherboard Replacement: adım 9, 1 resimden 1.
    • Remove the inner components from the outer shell.
  10. Chumby One Motherboard Replacement, Motherboard: adım 10, 1 resimden 1.
    • Remove the speaker connector using a plastic spudger.
  11. Chumby One Motherboard Replacement: adım 11, 1 resimden 1.
    • Remove the Chumby button connector using a plastic spudger.
  12. Chumby One Motherboard Replacement: adım 12, 1 resimden 1.
    • Remove three 6mm screws using a PH000 bit.
  13. Chumby One Motherboard Replacement: adım 13, 1 resimden 1.
    • Remove the motherboard by pulling straight away from the housing.
    • Removing the motherboard there are 2 pins and socket connectors that may cause injury.
Sonuç
Jordan Houchins
401 İtibar
4 adet Kılavuz yazıldı
Ekip
IUPUI, Team S3-G3, Baechle Spring 2017 IUPUI, Team S3-G3, Baechle Spring 2017 üyesi
IUPUI-BAECHLE-S17S3G3
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 368
