Ana içeriğe geç
Chumby One Speaker Replacement
Neye ihtiyacın var
  1. Chumby One Speaker Replacement, Chassis: adım 1, 1 resimden 1.
    • Remove 4 self-adhesive plastic dots covering the screw holes.
  2. Chumby One Speaker Replacement: adım 2, 1 resimden 1.
    • Remove the four 2mm screws with a Phillips screwdriver.
  3. Chumby One Speaker Replacement: adım 3, 1 resimden 1.
    • Remove the back and bottom cover.
  4. Chumby One Speaker Replacement: adım 4, 1 resimden 1.
    • Disconnect the battery connector from the motherboard with a plastic opening tool.
  5. Chumby One Speaker Replacement: adım 5, 1 resimden 1.
    • Disconnect the microphone connector from the motherboard with a plastic opening tool.
  6. Chumby One Speaker Replacement: adım 6, 1 resimden 1.
    • Remove the display ribbon cable from its socket with a plastic opening tool.
  7. Chumby One Speaker Replacement: adım 7, 1 resimden 1.
    • Remove the volume knob from the side of the Chumby One with a plastic opening tool.
  8. Chumby One Speaker Replacement: adım 8, 1 resimden 1.
    • Remove the four 6mm screws using a PH000 bit on the inner chassis.
  9. Chumby One Speaker Replacement: adım 9, 1 resimden 1.
    • Remove the inner components from the outer shell.
  10. Chumby One Speaker Replacement, Speaker: adım 10, 1 resimden 1.
    • Remove the speaker wire connector from the motherboard.
  11. Chumby One Speaker Replacement: adım 11, 2 resimden 1. Chumby One Speaker Replacement: adım 11, 2 resimden 2.
    • Remove the four 5mm screws on the speaker base with a Phillips PH00 screwdriver bit.
  12. Chumby One Speaker Replacement: adım 12, 1 resimden 1.
    • Remove the speaker.
Sonuç
Jordan Houchins
401 İtibar
4 adet Kılavuz yazıldı
Ekip
IUPUI, Team S3-G3, Baechle Spring 2017 IUPUI, Team S3-G3, Baechle Spring 2017 üyesi
IUPUI-BAECHLE-S17S3G3
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 8
Son 30 gün: 9
Her zaman: 198
