Parçalar
Hiçbir parçaya gerek yok.
    • Hold the phone with the back (camera side) facing you. Slide the battery cover off of the phone.
  1. Pull the battery out by lifting the black tab on the left side of the battery.
    • Pull the battery out by lifting the black tab on the left side of the battery.
  2. Remove the camera cover of the phone, using your light blue wedge tool.
    • Remove the camera cover of the phone, using your light blue wedge tool.
    • Unscrew the four black Torx head screws, found in each corner of the back.
    • Warning: Unscrewing the screw indicated in the picture will void any warranty on the phone.
  3. Use the light blue wedge tool to remove the back piece, which will reveal the green motherboard.
    • Use the light blue wedge tool to remove the back piece, which will reveal the green motherboard.
  4. Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
    • Remove the speakers from the motherboard by pulling firmly up on the black plastic piece.
  5. Attach new speakers by aligning the white squares on both the speakers and the motherboard, with the cords of the speaker facing the center of the motherboard.
    • Attach new speakers by aligning the white squares on both the speakers and the motherboard, with the cords of the speaker facing the center of the motherboard.
    • Press down on the white squares until they snap together.
  6. Place the back piece over the motherboard, making sure that the speakers align in place on the outside piece. (The black piece of the speaker will be against the holes in the dark grey back piece.)
    • Place the back piece over the motherboard, making sure that the speakers align in place on the outside piece. (The black piece of the speaker will be against the holes in the dark grey back piece.)
    • Screw the four Torx head screws back into place, securing the back piece onto the motherboard and rest of the phone.
    • Attach the camera cover by snapping it back into place.
    • Put battery back into place by lining the copper terminal on the battery with the terminal in the phone and push into place. Make sure the black tab sticks out.
    • Replace the battery cover by sliding and snapping it into place.
Sonuç
Laura Kimberly Simonds
301 İtibar
3 adet Kılavuz yazıldı
Takım
University of Maine, Team 1-1, Diaz Fall 2012 University of Maine, Team 1-1, Diaz Fall 2012 üyesi
UMAINE-DIAZ-F12S1G1
4 Üyeler
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 1
Her zaman: 196
