Ana içeriğe geç
Cirago M9030 Battery Replacement
Neye ihtiyacın var
  1. Cirago M9030 Battery Replacement, Cover: adım 1, 1 resimden 1.
    • Use a Phillips #00 screwdriver to unscrew the four 1.1mm long screws on each corner located at the top of the cover.
    FixBot'a Sor
    Yorum Ekle
  2. Cirago M9030 Battery Replacement: adım 2, 1 resimden 1.
    • Similar to the last step, flip the cover over and use a Phillips #00 screwdriver to unscrew the four 1.1mm long screws on each corner located at the bottom of the cover.
    • Remove the warranty sticker across the bottom.
    FixBot'a Sor
    Yorum Ekle
  3. Cirago M9030 Battery Replacement: adım 3, 2 resimden 1. Cirago M9030 Battery Replacement: adım 3, 2 resimden 2.
    • Gently take the cover apart using your hands separating the top and bottom.
    • The outer shell is expected to easily come apart.
    FixBot'a Sor
    Yorum Ekle
  4. Cirago M9030 Battery Replacement, Hard Drive: adım 4, 1 resimden 1.
    • Make sure that the screen of the device is facing down.
    FixBot'a Sor
    Yorum Ekle
  5. Cirago M9030 Battery Replacement: adım 5, 3 resimden 1. Cirago M9030 Battery Replacement: adım 5, 3 resimden 2. Cirago M9030 Battery Replacement: adım 5, 3 resimden 3.
    • Using the plastic opening tool, wedge the tool underneath the bottom left edge of the hard drive.
    • Raise the bottom edge of the hard drive 15 degrees up from the device.
    FixBot'a Sor
    Yorum Ekle
  6. Cirago M9030 Battery Replacement: adım 6, 3 resimden 1. Cirago M9030 Battery Replacement: adım 6, 3 resimden 2. Cirago M9030 Battery Replacement: adım 6, 3 resimden 3.
    • Place fingers on the IDE connectors gently picking up and sliding the hard drive out from the IDE module.
    FixBot'a Sor
    Yorum Ekle
  7. Cirago M9030 Battery Replacement, IDE Connector: adım 7, 2 resimden 1. Cirago M9030 Battery Replacement, IDE Connector: adım 7, 2 resimden 2.
    • Using the Phillips #00 screwdriver, unscrew the two 1.5mm long screws holding the IDE connector to the motherboard located at the top.
    FixBot'a Sor
    Yorum Ekle
  8. Cirago M9030 Battery Replacement: adım 8, 1 resimden 1.
    • Using the Phillips #00 screwdriver, unscrew the three 1.5mm long screws on the metal bracket.
    FixBot'a Sor
    Yorum Ekle
  9. Cirago M9030 Battery Replacement: adım 9, 2 resimden 1. Cirago M9030 Battery Replacement: adım 9, 2 resimden 2.
    • Using the plastic opening tool, completely lift the metal bracket off of the motherboard.
    • Using the plastic opening tool, completely lift the rubber insulator off of the motherboard.
    FixBot'a Sor
    Yorum Ekle
  10. Cirago M9030 Battery Replacement: adım 10, 1 resimden 1.
    • Using the plastic opening tool, completely lift the ribbon off of the motherboard.
    FixBot'a Sor
    Yorum Ekle
  11. Cirago M9030 Battery Replacement: adım 11, 2 resimden 1. Cirago M9030 Battery Replacement: adım 11, 2 resimden 2.
    • The audio jack is attached to the IDE connector. Pull at a 45 degree angle from the audio jack.
    • Completely remove the IDE connector from the device.
    FixBot'a Sor
    Yorum Ekle
  12. Cirago M9030 Battery Replacement, Motherboard: adım 12, 2 resimden 1. Cirago M9030 Battery Replacement, Motherboard: adım 12, 2 resimden 2.
    • Using the plastic opening tool, wedge the tool underneath the top edge of the motherboard.
    • Completely remove the motherboard.
    • The motherboard should slide out easily.
    FixBot'a Sor
    Yorum Ekle
  13. Cirago M9030 Battery Replacement, Button Module: adım 13, 1 resimden 1.
    • Set aside the front cover.
    • Flip over the motherboard.
    • Using the Philips #00 screwdriver, remove the three 4mm long screws holding down the button module.
    FixBot'a Sor
    Yorum Ekle
  14. Cirago M9030 Battery Replacement: adım 14, 3 resimden 1. Cirago M9030 Battery Replacement: adım 14, 3 resimden 2. Cirago M9030 Battery Replacement: adım 14, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Using the tweezers, lift up the button module to a 180 degree angle.
    • Leave the button module attached by the ribbon.
    • Flip over the motherboard with the button module still attached.
    FixBot'a Sor
    Yorum Ekle
  15. Cirago M9030 Battery Replacement: adım 15, 3 resimden 1. Cirago M9030 Battery Replacement: adım 15, 3 resimden 2. Cirago M9030 Battery Replacement: adım 15, 3 resimden 3.
    • Fold the button module over the motherboard.
    • Using the tweezers, remove the ribbon pin.
    • The ribbon pin should snap completely off of the motherboard.
    FixBot'a Sor
    Yorum Ekle
  16. Cirago M9030 Battery Replacement: adım 16, 2 resimden 1. Cirago M9030 Battery Replacement: adım 16, 2 resimden 2.
    • The ribbon should easily detach from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  17. Cirago M9030 Battery Replacement, Battery: adım 17, 2 resimden 1. Cirago M9030 Battery Replacement, Battery: adım 17, 2 resimden 2.
    • Flip over the motherboard so the screen faces up.
    • Carefully slide the battery off of the motherboard.
    • Leave the battery cable connected to the motherboard.
    FixBot'a Sor
    Yorum Ekle
  18. Cirago M9030 Battery Replacement: adım 18, 3 resimden 1. Cirago M9030 Battery Replacement: adım 18, 3 resimden 2. Cirago M9030 Battery Replacement: adım 18, 3 resimden 3.
    • Place two fingers on the battery connectors and gently pull the power cable connector completely out from the motherboard.
    • Do not pull directly on the wire as it may damage the connector.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ryan Sutardji
171 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 1-4, Regan SU 2012 Cal Poly, Team 1-4, Regan SU 2012 üyesi
CPSU-REGAN-SU12S1G4
4 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 34
Her zaman: 1,600
