Ana içeriğe geç
Cirago M9030 Button Module Replacement
Neye ihtiyacın var
  1. Cirago M9030 Button Module Replacement, Cover: adım 1, 1 resimden 1.
    • Use a Phillips #00 screwdriver to unscrew the four 1.1mm long screws on each corner located at the top of the cover.
    FixBot'a Sor
    Yorum Ekle
  2. Cirago M9030 Button Module Replacement: adım 2, 1 resimden 1.
    • Similar to the last step, flip the cover over and use a Phillips #00 screwdriver to unscrew the four 1.1mm long screws on each corner located at the bottom of the cover.
    • Remove the warranty sticker across the bottom.
    FixBot'a Sor
    Yorum Ekle
  3. Cirago M9030 Button Module Replacement: adım 3, 2 resimden 1. Cirago M9030 Button Module Replacement: adım 3, 2 resimden 2.
    • Gently take the cover apart using your hands separating the top and bottom.
    • The outer shell is expected to easily come apart.
    FixBot'a Sor
    Yorum Ekle
  4. Cirago M9030 Button Module Replacement, Hard Drive: adım 4, 1 resimden 1.
    • Make sure that the screen of the device is facing down.
    FixBot'a Sor
    Yorum Ekle
  5. Cirago M9030 Button Module Replacement: adım 5, 3 resimden 1. Cirago M9030 Button Module Replacement: adım 5, 3 resimden 2. Cirago M9030 Button Module Replacement: adım 5, 3 resimden 3.
    • Using the plastic opening tool, wedge the tool underneath the bottom left edge of the hard drive.
    • Raise the bottom edge of the hard drive 15 degrees up from the device.
    FixBot'a Sor
    Yorum Ekle
  6. Cirago M9030 Button Module Replacement: adım 6, 3 resimden 1. Cirago M9030 Button Module Replacement: adım 6, 3 resimden 2. Cirago M9030 Button Module Replacement: adım 6, 3 resimden 3.
    • Place fingers on the IDE connectors gently picking up and sliding the hard drive out from the IDE module.
    FixBot'a Sor
    Yorum Ekle
  7. Cirago M9030 Button Module Replacement, IDE Connector: adım 7, 2 resimden 1. Cirago M9030 Button Module Replacement, IDE Connector: adım 7, 2 resimden 2.
    • Using the Phillips #00 screwdriver, unscrew the two 1.5mm long screws holding the IDE connector to the motherboard located at the top.
    FixBot'a Sor
    Yorum Ekle
  8. Cirago M9030 Button Module Replacement: adım 8, 1 resimden 1.
    • Using the Phillips #00 screwdriver, unscrew the three 1.5mm long screws on the metal bracket.
    FixBot'a Sor
    Yorum Ekle
  9. Cirago M9030 Button Module Replacement: adım 9, 2 resimden 1. Cirago M9030 Button Module Replacement: adım 9, 2 resimden 2.
    • Using the plastic opening tool, completely lift the metal bracket off of the motherboard.
    • Using the plastic opening tool, completely lift the rubber insulator off of the motherboard.
    FixBot'a Sor
    Yorum Ekle
  10. Cirago M9030 Button Module Replacement: adım 10, 1 resimden 1.
    • Using the plastic opening tool, completely lift the ribbon off of the motherboard.
    FixBot'a Sor
    Yorum Ekle
  11. Cirago M9030 Button Module Replacement: adım 11, 2 resimden 1. Cirago M9030 Button Module Replacement: adım 11, 2 resimden 2.
    • The audio jack is attached to the IDE connector. Pull at a 45 degree angle from the audio jack.
    • Completely remove the IDE connector from the device.
    FixBot'a Sor
    Yorum Ekle
  12. Cirago M9030 Button Module Replacement, Motherboard: adım 12, 2 resimden 1. Cirago M9030 Button Module Replacement, Motherboard: adım 12, 2 resimden 2.
    • Using the plastic opening tool, wedge the tool underneath the top edge of the motherboard.
    • Completely remove the motherboard.
    • The motherboard should slide out easily.
    FixBot'a Sor
    Yorum Ekle
  13. Cirago M9030 Button Module Replacement, Button Module: adım 13, 1 resimden 1.
    • Set aside the front cover.
    • Flip over the motherboard.
    • Using the Philips #00 screwdriver, remove the three 4mm long screws holding down the button module.
    FixBot'a Sor
    Yorum Ekle
  14. Cirago M9030 Button Module Replacement: adım 14, 3 resimden 1. Cirago M9030 Button Module Replacement: adım 14, 3 resimden 2. Cirago M9030 Button Module Replacement: adım 14, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Using the tweezers, lift up the button module to a 180 degree angle.
    • Leave the button module attached by the ribbon.
    • Flip over the motherboard with the button module still attached.
    FixBot'a Sor
    Yorum Ekle
  15. Cirago M9030 Button Module Replacement: adım 15, 3 resimden 1. Cirago M9030 Button Module Replacement: adım 15, 3 resimden 2. Cirago M9030 Button Module Replacement: adım 15, 3 resimden 3.
    • Fold the button module over the motherboard.
    • Using the tweezers, remove the ribbon pin.
    • The ribbon pin should snap completely off of the motherboard.
    FixBot'a Sor
    Yorum Ekle
  16. Cirago M9030 Button Module Replacement: adım 16, 2 resimden 1. Cirago M9030 Button Module Replacement: adım 16, 2 resimden 2.
    • The ribbon should easily detach from the motherboard.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Ryan Sutardji
171 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 1-4, Regan SU 2012 Cal Poly, Team 1-4, Regan SU 2012 üyesi
CPSU-REGAN-SU12S1G4
4 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 36
Her zaman: 1,335
