Ana içeriğe geç
Cirago M9030 Cover Replacement
Neye ihtiyacın var
  1. Cirago M9030 Cover Replacement, Cover: adım 1, 1 resimden 1.
    • Use a Phillips #00 screwdriver to unscrew the four 1.1mm long screws on each corner located at the top of the cover.
  2. Cirago M9030 Cover Replacement: adım 2, 1 resimden 1.
    • Similar to the last step, flip the cover over and use a Phillips #00 screwdriver to unscrew the four 1.1mm long screws on each corner located at the bottom of the cover.
    • Remove the warranty sticker across the bottom.
  3. Cirago M9030 Cover Replacement: adım 3, 2 resimden 1. Cirago M9030 Cover Replacement: adım 3, 2 resimden 2.
    • Gently take the cover apart using your hands separating the top and bottom.
    • The outer shell is expected to easily come apart.
Sonuç
In order to reassemble your device, follow these instructions in reverse order.
Bir başkası bu kılavuzu tamamladı.
Ryan Sutardji
171 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 1-4, Regan SU 2012 Cal Poly, Team 1-4, Regan SU 2012 üyesi
CPSU-REGAN-SU12S1G4
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 879
