Ana içeriğe geç
Cirago M9030 Hard Drive Replacement
Neye ihtiyacın var
  1. Cirago M9030 Hard Drive Replacement, Cover: adım 1, 1 resimden 1.
    • Use a Phillips #00 screwdriver to unscrew the four 1.1mm long screws on each corner located at the top of the cover.
  2. Cirago M9030 Hard Drive Replacement: adım 2, 1 resimden 1.
    • Similar to the last step, flip the cover over and use a Phillips #00 screwdriver to unscrew the four 1.1mm long screws on each corner located at the bottom of the cover.
    • Remove the warranty sticker across the bottom.
  3. Cirago M9030 Hard Drive Replacement: adım 3, 2 resimden 1. Cirago M9030 Hard Drive Replacement: adım 3, 2 resimden 2.
    • Gently take the cover apart using your hands separating the top and bottom.
    • The outer shell is expected to easily come apart.
  4. Cirago M9030 Hard Drive Replacement, Hard Drive: adım 4, 1 resimden 1.
    • Make sure that the screen of the device is facing down.
  5. Cirago M9030 Hard Drive Replacement: adım 5, 3 resimden 1. Cirago M9030 Hard Drive Replacement: adım 5, 3 resimden 2. Cirago M9030 Hard Drive Replacement: adım 5, 3 resimden 3.
    • Using the plastic opening tool, wedge the tool underneath the bottom left edge of the hard drive.
    • Raise the bottom edge of the hard drive 15 degrees up from the device.
  6. Cirago M9030 Hard Drive Replacement: adım 6, 3 resimden 1. Cirago M9030 Hard Drive Replacement: adım 6, 3 resimden 2. Cirago M9030 Hard Drive Replacement: adım 6, 3 resimden 3.
    • Place fingers on the IDE connectors gently picking up and sliding the hard drive out from the IDE module.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ryan Sutardji
171 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 1-4, Regan SU 2012 Cal Poly, Team 1-4, Regan SU 2012 üyesi
CPSU-REGAN-SU12S1G4
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 925
