Ana içeriğe geç
Circuit Board Housing Removal
Neye ihtiyacın var
  1. Circuit Board Housing Removal, Battery: adım 1, 2 resimden 1. Circuit Board Housing Removal, Battery: adım 1, 2 resimden 2.
    • Locate the horizontal grip located on the back cover of the phone.
    • Slide the back cover down and off of the phone.
  2. Circuit Board Housing Removal: adım 2, 2 resimden 1. Circuit Board Housing Removal: adım 2, 2 resimden 2.
    • Insert a plastic opening tool into the battery release point located above the battery.
    • Pull outwards in order to release the battery.
  3. Circuit Board Housing Removal, Circuit Board Housing: adım 3, 3 resimden 1. Circuit Board Housing Removal, Circuit Board Housing: adım 3, 3 resimden 2. Circuit Board Housing Removal, Circuit Board Housing: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Locate the 5 screws holding the body of the phone together.
    • The top screw will have a plastic cover, remove it using tweezers.
    • Using a Philips head screwdriver, twist counterclockwise to remove the screws.
    • Take special care with the screw located at the top of the phone. It is smaller and more likely to be damaged or improperly attached.
  4. Circuit Board Housing Removal: adım 4, 2 resimden 1. Circuit Board Housing Removal: adım 4, 2 resimden 2.
    • Lift the back cover starting at the bottom of the phone.
  5. Circuit Board Housing Removal: adım 5, 2 resimden 1. Circuit Board Housing Removal: adım 5, 2 resimden 2.
    • Remove the back cover completely from the phone.
Sonuç
Jonathan Flowers
607 İtibar
6 adet Kılavuz yazıldı
Ekip
Clemson, Team 14-7, Benson Fall 2013 Clemson, Team 14-7, Benson Fall 2013 üyesi
CLEM-BENSON-F13S14G7
3 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 624
