Ana içeriğe geç
Circuit Board
Neye ihtiyacın var
    1. Circuit Board, Battery: adım 1, 2 resimden 1. Circuit Board, Battery: adım 1, 2 resimden 2.
      • Locate the horizontal grip located on the back cover of the phone.
      • Slide the back cover down and off of the phone.
      FixBot'a Sor
      Yorum Ekle
    2. Circuit Board: adım 2, 2 resimden 1. Circuit Board: adım 2, 2 resimden 2.
      • Insert a plastic opening tool into the battery release point located above the battery.
      • Pull outwards in order to release the battery.
      FixBot'a Sor
      Yorum Ekle
    1. Circuit Board, Circuit Board Housing: adım 3, 3 resimden 1. Circuit Board, Circuit Board Housing: adım 3, 3 resimden 2. Circuit Board, Circuit Board Housing: adım 3, 3 resimden 3.
      Bu adımda kullanılan alet:
      • Locate the 5 screws holding the body of the phone together.
      • The top screw will have a plastic cover, remove it using tweezers.
      • Using a Philips head screwdriver, twist counterclockwise to remove the screws.
      • Take special care with the screw located at the top of the phone. It is smaller and more likely to be damaged or improperly attached.
      FixBot'a Sor
      Yorum Ekle
    2. Circuit Board: adım 4, 2 resimden 1. Circuit Board: adım 4, 2 resimden 2.
      • Lift the back cover starting at the bottom of the phone.
      FixBot'a Sor
      Yorum Ekle
    3. Circuit Board: adım 5, 2 resimden 1. Circuit Board: adım 5, 2 resimden 2.
      • Remove the back cover completely from the phone.
      FixBot'a Sor
      Yorum Ekle
    1. Circuit Board, Circuit Board: adım 6, 1 resimden 1.
      • Locate the clamp at bottom right side of the Circuit Board.
      • Pull the circuit board from the phone being cautious to pull out underneath the clamp.
      FixBot'a Sor
      Yorum Ekle
    2. Circuit Board: adım 7, 2 resimden 1. Circuit Board: adım 7, 2 resimden 2.
      • Locate the ribbon connecting the circuit board to the phone display.
      • Using the spudger, disconnect the ribbon connecting the phone's display and the circuit board.
      • Remove the circuit board
      FixBot'a Sor
      Yorum Ekle
Sonuç
Jonathan Flowers
628 İtibar
6 adet Kılavuz yazıldı
Ekip
Clemson, Team 14-7, Benson Fall 2013 Clemson, Team 14-7, Benson Fall 2013 üyesi
CLEM-BENSON-F13S14G7
3 Üyeler
96 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 18
Her zaman: 836
