Ana içeriğe geç
Circular Saw Blade Replacement
  1. Circular Saw Blade Replacement, Blade: adım 1, 2 resimden 1. Circular Saw Blade Replacement, Blade: adım 1, 2 resimden 2.
    • Unplug your circular saw or remove the battery before replacing the blade!
  2. Circular Saw Blade Replacement: adım 2, 3 resimden 1. Circular Saw Blade Replacement: adım 2, 3 resimden 2. Circular Saw Blade Replacement: adım 2, 3 resimden 3.
    • Press and hold down the blade lock button to keep the blade from turning while you loosen it.
    • Loosen the arbor's hex bolt in the center of the blade using a 5mm hex key, making sure to loosen clockwise since the bolt threads are reversed.
    • Your circular saw may already come with a hex key.
  3. Circular Saw Blade Replacement: adım 3, 2 resimden 1. Circular Saw Blade Replacement: adım 3, 2 resimden 2.
    • Once loosened, continue unscrewing the bolt with your fingers and remove it from the saw.
  4. Circular Saw Blade Replacement: adım 4, 2 resimden 1. Circular Saw Blade Replacement: adım 4, 2 resimden 2.
    • Remove the arbor washer.
  5. Circular Saw Blade Replacement: adım 5, 3 resimden 1. Circular Saw Blade Replacement: adım 5, 3 resimden 2. Circular Saw Blade Replacement: adım 5, 3 resimden 3.
    • Completely retract the blade guard.
    • You can hold the blade guard in place with a clamp while you change the blade.
  6. Circular Saw Blade Replacement: adım 6, 3 resimden 1. Circular Saw Blade Replacement: adım 6, 3 resimden 2. Circular Saw Blade Replacement: adım 6, 3 resimden 3.
    • Set the circular saw on its side and carefully lift up the blade to unseat it from the arbor.
    • Slowly slide out the blade.
    • Use extreme caution when handling the blade!
  7. Circular Saw Blade Replacement: adım 7, 1 resimden 1.
    • When inserting the new blade, be sure to note its rotation and install it in the correct orientation.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Craig Lloyd
33.049 İtibar
82 adet Kılavuz yazıldı
Bir Yorum
Hello!
I learned a lot of important things, but I have a Question that is this Circular Saw perfect to cut Concrete Pavers?
F6 Adhesive Tape - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 20
Son 30 gün: 78
Her zaman: 5,514
