Ana içeriğe geç
Cisco 878 Integrated Services Router Top Cover Disassembly
Neye ihtiyacın var
  1. Cisco 878 Integrated Services Router Top Cover Disassembly, Remove the two screws on back side: adım 1, 3 resimden 1. Cisco 878 Integrated Services Router Top Cover Disassembly, Remove the two screws on back side: adım 1, 3 resimden 2. Cisco 878 Integrated Services Router Top Cover Disassembly, Remove the two screws on back side: adım 1, 3 resimden 3.
    • Only trained and qualified personnel should be allowed to install, replace, or service this equipment!
    • During this procedure, wear grounding wrist straps to avoid ESD damage to the card. Do not directly touch the backplane with your hand or any metal tool, or you could shock yourself!
    • Make sure that the power switch is turned to standby and that the power supply cable is disconnected. Disconnect all cables from the router back panel.
    • Use the Phillips #1 Screwdriver to remove the two screws on back side of the device.
  2. Cisco 878 Integrated Services Router Top Cover Disassembly, Remove top cover: adım 2, 3 resimden 1. Cisco 878 Integrated Services Router Top Cover Disassembly, Remove top cover: adım 2, 3 resimden 2. Cisco 878 Integrated Services Router Top Cover Disassembly, Remove top cover: adım 2, 3 resimden 3.
    • 1. Gently push the top cover of the router away from you.
    • 2. Lift it up top cover from the bottom of the router.
    • 3. Remove top cover from the device.
    • Place the router bottom on an antistatic mat.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jiri Altman
1.515 İtibar
9 adet Kılavuz yazıldı
Ekip
4k20 Repair Team 4k20 Repair Team üyesi
Community
2 Üyeler
17 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 6
Her zaman: 237
