Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
Disassembly guide for Cisco Aironet 1242ag Access Point
Aletler
Parçalar
Hiçbir parça belirtilmedi.
  1. The equipment cover is held by 4 screws. The equipment cover is held by 4 screws.
    • The equipment cover is held by 4 screws.
  2. Once the 4 screws are removed, push to the side to remove the cover.
    • Once the 4 screws are removed, push to the side to remove the cover.
  3. The card is attached to the bottom plate by 4 screws Before removing the logic board, disconnect the antenna cables in both parts of the device. There is a total of 4 cables. Use a tweezer or a spudger to disconnect them.
    • The card is attached to the bottom plate by 4 screws
    • Before removing the logic board, disconnect the antenna cables in both parts of the device.
    • There is a total of 4 cables. Use a tweezer or a spudger to disconnect them.
  4. Write the wisdom here. Write the wisdom here. Write the wisdom here.
    • Write the wisdom here.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
Eneider Colina
1.444 İtibar
9 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 449
