Ana içeriğe geç
Cisco Meraki MC74-HW Sensor Cover Replacement
Neye ihtiyacın var
  1. Cisco Meraki MC74-HW Sensor Cover Replacement, Back Housing and Device Stand: adım 1, 3 resimden 1. Cisco Meraki MC74-HW Sensor Cover Replacement, Back Housing and Device Stand: adım 1, 3 resimden 2. Cisco Meraki MC74-HW Sensor Cover Replacement, Back Housing and Device Stand: adım 1, 3 resimden 3.
    • Extend the stand as far away as possible from the device.
    • Remove all four 3 mm Hex 2 screws from the stand.
    • A bit with a flexible extension may be needed to remove these screws.
  2. Cisco Meraki MC74-HW Sensor Cover Replacement: adım 2, 2 resimden 1. Cisco Meraki MC74-HW Sensor Cover Replacement: adım 2, 2 resimden 2.
    • Lift the stand off the device.
  3. Cisco Meraki MC74-HW Sensor Cover Replacement: adım 3, 3 resimden 1. Cisco Meraki MC74-HW Sensor Cover Replacement: adım 3, 3 resimden 2. Cisco Meraki MC74-HW Sensor Cover Replacement: adım 3, 3 resimden 3.
    • Insert a plastic spudger between the back housing cover and the sensor cover piece.
    • Work your way slowly around the edges of the device until all the clips have been unclipped.
    • Do not insert any tool recklessly into the device or you might damage wires and connections.
  4. Cisco Meraki MC74-HW Sensor Cover Replacement: adım 4, 2 resimden 1. Cisco Meraki MC74-HW Sensor Cover Replacement: adım 4, 2 resimden 2.
    • Separate the back housing cover from the device completely.
  5. Cisco Meraki MC74-HW Sensor Cover Replacement, Phone Sensor: adım 5, 2 resimden 1. Cisco Meraki MC74-HW Sensor Cover Replacement, Phone Sensor: adım 5, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Disconnect the ribbon from the phone sensor board using a pair of reverse tweezers.
    • Electronic ribbons are very fragile, so pull slowly to disconnect them.
  6. Cisco Meraki MC74-HW Sensor Cover Replacement: adım 6, 3 resimden 1. Cisco Meraki MC74-HW Sensor Cover Replacement: adım 6, 3 resimden 2. Cisco Meraki MC74-HW Sensor Cover Replacement: adım 6, 3 resimden 3.
    • Remove the two 1.2 mm screws holding the phone sensor using a Phillips #0 screwdriver.
    • Carefully lift the phone sensor to remove it from the device.
  7. Cisco Meraki MC74-HW Sensor Cover Replacement, Sensor Cover: adım 7, 3 resimden 1. Cisco Meraki MC74-HW Sensor Cover Replacement, Sensor Cover: adım 7, 3 resimden 2. Cisco Meraki MC74-HW Sensor Cover Replacement, Sensor Cover: adım 7, 3 resimden 3.
    • Remove the two 1.2 mm screws using a Phillips #0 screwdriver.
    • Remove the sensor cover.
Sonuç
Anthony Kairouz
253 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-5, Simcock Fall 2021 UMass Dartmouth, Team 1-5, Simcock Fall 2021 üyesi
UMASSD-SIMCOCK-F21S1G5
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 9
Her zaman: 122
